How di I remove tar from paint?????
Old Sep 16, 2001 | 06:32 AM
lemans396's Avatar
lemans396
Default How di I remove tar from paint?????
Any ideas how to get tar off of exterior without damaging paint?
:confused:
Old Sep 16, 2001 | 07:46 AM
steve1ph's Avatar
steve1ph
Default Re: How di I remove tar from paint????? (lemans396)
you may not belive this but i bought some stuff from auto zone works great thats not the unbeliveable part, i will bet my life on this its straight diesel fuel. so if you got any of that stuff handy try that.
Old Sep 16, 2001 | 10:02 AM
MBVette's Avatar
MBVette
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: How di I remove tar from paint????? (steve1ph)
go to autozone and buy some bug and tar remover. the cans usually say they are safe to use on clear coats and such. But I always make sure re-wax any spot I use the stuff on.
Old Sep 16, 2001 | 10:21 AM
tacblu's Avatar
tacblu
What works best for me is WD-40.
Old Sep 16, 2001 | 10:41 AM
Black ZR1's Avatar
Black ZR1
Default Re: How di I remove tar from paint????? (tacblu)
I've used straight Zaino wash for this before.
Old Sep 16, 2001 | 10:55 AM
Lloyd Smale's Avatar
Lloyd Smale
any thin (penetrating type) oil will work
Old Sep 16, 2001 | 01:55 PM
Gatorac's Avatar
Gatorac
WD-40 :yesnod:
Old Sep 16, 2001 | 02:29 PM
scorp508's Avatar
scorp508
3M Bug/Tar/Adhesive remover.... or Claybar.
Old Sep 16, 2001 | 03:42 PM
TrplBlk01's Avatar
TrplBlk01
mineral spirits.... :flag
Old Sep 16, 2001 | 05:41 PM
lemans396's Avatar
lemans396
Default Re: How di I remove tar from paint????? (blk91)
Thanks.
Old Sep 16, 2001 | 06:06 PM
lemans396's Avatar
lemans396
Would brake cleaner (brake kleen) work?
Old Sep 16, 2001 | 08:42 PM
EtidW's Avatar
EtidW
WD-40 works great
Old Sep 16, 2001 | 10:45 PM
mash557's Avatar
mash557
I have used laquer thinner with good results. Just don't use it on laquer paint!!! It also has worked well for getting rid of paint from other peoples doors when they get carried away slamming them open. :mad
Old Sep 16, 2001 | 10:49 PM
C4396roadster's Avatar
C4396roadster
wd-40/7-up/bug and tar remover etc or regular wax whatever is withing reach.
Old Sep 17, 2001 | 01:34 AM
jkingsbury's Avatar
jkingsbury
kerosene - rub some on, let it soak for a minute, and then rub off with a kerosene soaked rag (not TOO soaked). Cheap solution.
Old Sep 17, 2001 | 08:46 AM
89 Bob L's Avatar
89 Bob L
WD-40 works great!!!!!
Old Sep 17, 2001 | 03:13 PM
1991Z07's Avatar
1991Z07
Absolutely NOT!!!
I've used WD-40 before with good results. I also have a can of grease/tar remover that I got at Home Depot. It gets the really nasty stuff off...
To How di I remove tar from paint?????
Old Sep 17, 2001 | 07:49 PM
CAPN17's Avatar
CAPN17
Best I have ever seen is PB Blaster or Liquid Wrench, tar comes right off.
Old Sep 17, 2001 | 08:19 PM
black bart's Avatar
black bart
YEE GADS DON'T USE BRAKE FLUID THAT WILL REMOVE THE PAINT :nono:
Stuff that you buy in the store is kerosene soak a rag with a little kerosene or fuel oil diesel fuel will work. Wash off with soap and water then wax. :cool:
She will look as good as new. :yesnod:
Old Sep 17, 2001 | 08:36 PM
rcolling's Avatar
rcolling
Default Re: How di I remove tar from paint????? (black bart)
WD-40
and Sal says that it does not even remove the Zaino!
