AFR Heads again!
One pulled to redline as clean as a whistle; the other blew smoke out of the breather like one of those old coal burning locomotives.
Seems that one guy had figured it out and the other hadn't.
Jake
with a Canton road race pan.
larger primaries?
My Canton and Armando's RR pans both went in and out relatively
easily with 1-5/8" StainlessWorks headers (and I have the OEM
oil cooler coolant tube under the pan ahead of the sump that is
almost certainly not in place on the subject car.)
http://www.grandsportregistry.com/lt1vslt4.htm#RINGS
This statement speaks volumes:
"High-speed durability tests of the engine revealed that ring flutter became a serious problem above 5,500 rpm, and the result was excessive blow-by."
GM obviously has a lot more capability to research this problem than I do. So, assuming that statement is fact, that tells me any LT1 engine going past 5500 will have "serious blow-by" problems without doing something about it.
As I have stated before, my '92 LT1 has AFR heads with the same drain-backs as others and I have never had a problem in 40K miles. But, I have stock short-block and an A4 that shifts at about 5500 so I don't get into the RPM range that GM says is a problem.
My belief is that anyone building a higher reving engine should look into decreasing blow-by to attack the source of the problem.
It seems to me, that looking at valve seals, lower-volume oil pumps, etc., is attacking the symptoms instead of the problem.
Unfortunately, after an engine is already built, it is much more time consuming and expensive to attack blow-by problems.
If I were building a new engine from scratch, I would be looking at things that decrease blow-by.
In particular, I would question using forged pistons with excess clearances, and I would be looking at rings designed in particular for that -- I would be looking at ways to decrease clearances and keeping blow-by to a minimum. A certain amount of clearance and blow-by may be acceptible in Grandmas barge, but if she puts heads and a cam in it and revs it to 7K, those same clearances may become fatal.
If you build an engine and have to add breathers to the valve covers etc., to me, you have confirmed you have a serious crankcase pressure/blow-by problem that needs to be addressed.
In the late '50s and very early '60s, vehicles had "road draft" tubes that vented directly from the crankcase (usually with some type of oil separater) to the atmosphere instead of only through the valve covers. But, "closed" Positive Crankcase Ventilation did away with that.
Tom Piper
I burn about a quart a tank or so or a little more. Unless my oil pan is completely full, I can watch my oil pressure dive during hard acceleration. I'm also running a stock oil pump with no windage pan under the crank. BTW, I do not have oil that leaks out of the head when I remove the valve cover for what it is worth.
I believe it was Smokey that ran some tests many years ago and actually saw the oil pan balloon from the increased blow-by.
Engines designed to high RPM should always have thinner - hence lighter -ring packages. There are pros and cons to each though.
5/64th rings seal better at the RPMs the engine is designed for and will normally see, but once the R's climb to above 5500 or so, engines will generally need 1/16th or even thinner rings. Has to due with ring inertia as the piston changes direction from up to down.
There are several other ways to address ring flutter including changing the traditional ring gap recommendations. A few years back, Speed Pro and others changed their recommendation on the top and second ring gaps to address the issue.
Some of the newer design pistons incorporate a groove in the piston below the top ring land to address, I believe, blow-by and flutter.
I called Speed Pro as I was assembling the 415 engine to go in my 86 and learned about the results of their most recents tests on ring gaps. I became convinced and used their new recommendation when I gapped my +.005 plasma molys.
Even with all those changes, flutter and blow-by can still be a problem; hence the move to vacuum pumps to better control blow-by. Some of you guys who have actually had to resort to that measure can comment on it's effectiveness, but I believe just about all of the top Pro Stock guys, and other professional racers run one.
All those wondrous "R's" come at a price.
Jake
If it smokes on WOT, there is very little vacuum in the intake and runners -- so, I believe it is because the crankcase pressure is blowing it past the valve seals.
Tom Piper
Jake
Low tension oil ring sets free up a few HP in certain RACE engines, but they don't perform well in street driven engines.
I don't recall the exact percentages, but I've read test results that show the greatest power loss results from piston ring friction against the cylinder walls. Of the three, the oil ring set causes the greatest loss by far and is the biggest offender. That's the thinking behind low tension oil rings sets; less friction more HP.
When I was building quarter-mile BB Chevy engines that were intended to go a full season without a re-build and were expected to run extremely consistent ETs, I INSISTED on standard tension oil rings.
Jake
My owner built 11.9 to 1, 381 runs Plasma Moly rings I customed gapped-tight with the SRP pistons (with standard tension, but narrow rings-std spec for SRPs) and it burns next to no oil.
I shift at 7000 rpm and ran 7000 miles of One Lap using maybe 2 to 2.5 quarts.
5W30 Mobil 1 always with the Canton road race pan and 300 degree temps were common (coolant of 230 at times too!).
Even locally when I do a 100 miles on the road course...the oil quantity drops only marginally...
I would like to say I'm the cause of the oil tightness, but it is more pure luck!
I don't even want to take it apart again, but more hp is required...
You may wish to consult again with your builder and press him as to exactly why he thought you'd be happy with low-tension. Maybe you told him from the beginning it would be used more for drag racing than anything else? If this is true, thats explains it. It also explains why you're consuming so much oil, for street use.
Just my .02, hope its useful in some way. Please understand I'm not an expert from experience, just going by what I've been told. I wish you best luck
I am concerned of the oil blow by though that TJ is working on here. I am going to look into a better breather system than the one I have, and to fix my crimped hose for my PCV valve on the drivers side of the manifold.
Heres the data on these pistons, they are plasma moly coated.
http://www.jegs.com/webapp/wcs/store...20537_-1_10221
Speed Pro's SS50U oil ring set is the ABSOLUTE BEST oil ring set on the market. Has been for a long, long time.
For me, there's no other way to go.
Jake
