383 Stroker price help
Old Oct 9, 2006 | 07:26 PM
BOWLING GREEN's Avatar
BOWLING GREEN
Default 383 Stroker price help
Help on information on 383 motor. Found a shop that will rebuild my 1991 350 into a 383. Balanced and blue printed. Drive it in drive it out for $6000. I was thinking around $4000. Was I dreaming? I said there is 6 ways to build one and he said yes but one way if you want it to hold together. He said it would be as true as it could be for flat and inline. Had it in my mind I was ready to pop for $4000. but $6000. is a hard bight with a big chew and hard to swallow. One year warranty. Shop in Minneapolis Minnesota. They did good work on my 1993 1 ton duely two years ago. Spendy but it stayed home after I picked it up. No take it back or fix what they didn't finished. I'm just like a jack ***. I'm all ears. What your input? Speed ain't cheep! Thanks.
Old Oct 9, 2006 | 07:39 PM
93 ragtop's Avatar
93 ragtop
I think alot would depend on what they use ie: forged parts vs cast. Brand name etc. There are alot of little parts that will add up fast when trying to break down a price. Gaskets, fluids, oil, computer tuning etc. In my opinion 6000 is not to far out of line for turn key, but wait for others to speak up on that. Good luck.
Old Oct 9, 2006 | 08:41 PM
stubbs's Avatar
stubbs
I'm in the middle of a 383 build right now. Forged rotating assembly, Dart heads, custom intake, etc and all the supporting stuff(bigger radiator, injectors, fuel pump, centerforce cluth etc) and I'm over 11 grand. But I'm doing everything right. My labor just on the motor is almost 5k. You need to get IN WRITING exactly what he will do. What parts EXACTLY he will use. How is he plannings on prepping the block? Stock blocks are 2 bolt, you can splay bolt a 2 to a 4 but it's a grand just to splay it. Or is he getting a seperate block that is a 4 already? You have no idea the nightmare stories I can tell you, my car hasn't had a motor since Jan 8th. Do yourself a favor and get EVERY LITTLE DETAIL in writing. Leave nothing to chance, don't make my mistakes.
Old Oct 9, 2006 | 10:28 PM
bobmic93's Avatar
bobmic93
Here in Chicago a place called Speed Inc charges 6000 but it included afr heads and cam, rockers but its 3500 for the bottom end only. Look at there web site as a reference to use.
Old Oct 10, 2006 | 05:58 AM
Leftoverture's Avatar
Leftoverture
Boos Performance? If that's where you're going, I think you'll be happy with the results.
Old Oct 10, 2006 | 10:28 AM
dogbon's Avatar
dogbon
My 383 is a DIY and ran around 5500.00
Old Oct 10, 2006 | 03:39 PM
edcmat-l1's Avatar
edcmat-l1
4 Gs will barely buy a quality short block, let alone a long block WITH installation. Your last sentence sums it up. BTW 6 Gs aint bad either. I'll bet by the time your out the door AND tuned its more than that. Just an opinion
Old Oct 10, 2006 | 03:51 PM
stearnman's Avatar
stearnman
... Drive it in drive it out for $6000. ...
Your quote there... That would be my relative guess in the price difference $6000 for someone else to do the work vs $4000 for you to do the work?
Old Oct 10, 2006 | 05:29 PM
danziger's Avatar
danziger
Yikes! Way more than I would pay, but it depends on what your goals are. I had a reknowned local shop build a budget 383 using good parts for a little over $2K. However, it is a mild build that will be in a street car, not on the strip. Don't foget all the other stuff that a 383 will need if you haven't upgraded already, like headers/exhaust, intake, AFPR, etc...
Old Oct 10, 2006 | 05:41 PM
edcmat-l1's Avatar
edcmat-l1
They built the motor, you took it out and put it in. Right? also the add ons your talking about will add up considerably, as I'm sure you can atest to.
Old Oct 10, 2006 | 06:02 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Depending on what they're using, if it's decent stuff that's not too bad. R&Ring the engine, assembling and checking everything, etc. done right is a time consumming job. I've easily got $3500 or more in my latest short block. That's just a rough estimate, I really didn't keep up with every penny, I just did it. And I did everything except the machine work myself. I've got $1700 and change just in the crank, rods, pistons, rings and bearings. Forged stuff can be had cheaper but I wanted lightweight stuff. But they're not by far the most expensive components available either. I also had to get a neutral balanced flexplate because I went with complete neutral balance, not just internal. A fresh DR timing set, blue printed oil pump, hardened shaft, expensive head gaskets and all quality gaskets and seals, etc., etc., the list goes on. If they have to do any block clearancing, that takes a while. That's something I was able to do myself as well as the de-burring, optimizing oil returns, etc. The point is, you can get a lot of time, money and work wrapped up into such a project. But IMO, if they're using decent components and doing everything necessary for reliability and longevity, it's a very fair price. I couldn't and wouldn't do it for much less for someone, here at home in my own shop.
Old Oct 10, 2006 | 06:09 PM
400hpnatural86's Avatar
400hpnatural86
8th Gear
Default stroker
Do you know any one at holley get system max heads a lunati voodoo cam rooler rockers and lifters. 3000 stall and a 383 bottom end from grooms. thats about 4500 dollars you can get it in bowling green. OH YEAH 1000.00 TO PUT IT TOGETHER AND INSTALL. THEN THE TUNE, YOU NEED TO GET THE HORSE POWER HOUSE TO GET THAT DONE GOOD LUCK.
Old Oct 10, 2006 | 06:22 PM
rick lambert's Avatar
rick lambert
If I were gonna do it..I'd have the machine work done, use forged cause I like the idea of adding N20..I honestly think you should be doing some web searches cause going against the grain... I think you can do better.
Old Oct 10, 2006 | 06:23 PM
Corvette Kid
Punctuation, look into it.....
Old Oct 10, 2006 | 07:12 PM
rick lambert
check out the post by Archaea "what's the highest performing crate, et.etc. bottom of this page..think you'll see what I meant.
Old Oct 10, 2006 | 07:20 PM
cakes751's Avatar
cakes751
if it's any consolation, my mechanics want $15,000 to do the job...
Old Oct 10, 2006 | 09:22 PM
chucks88's Avatar
chucks88
This is where I am at
Machining to a 383 + installing all forged internals...............$2700
used Super Ram..................................... ......................$850
new TPIS headers................................. .......................$750
used AFR 190's................................... ..........................$1200
Cam/valvetrain.............................. ...............................$1000
and thats with me pulling my motor, dropping it off, bolting down the top half and dropping it back in my car. I didn't even include the small stuff like gaskets, bolts timing chain, oil pump, water pump. ETC.
HOLY CRAP...what have I got my self into
To 383 Stroker price help
Old Oct 10, 2006 | 09:49 PM
edcmat-l1's Avatar
edcmat-l1
.......thats phunnnie!!!!
Old Oct 11, 2006 | 10:42 AM
hardlight's Avatar
hardlight
I just finished my 91 383 project. Had it done by a local racing engine shop. By the time I picked out all of the components I wanted for the internals, bought a Super Ram, chromed it, put Stainless Works headers on it, the reinstall, tuning the chip, I'm past 11 grand. Now if it would just start and stay running on the first crank, it would be heaven. Gotta keep it going with my foot for about a minute or so and then every thing is cool.
Old Oct 11, 2006 | 10:58 AM
edcmat-l1's Avatar
edcmat-l1
Sent you a PM
