Man, I need help BAD !!
Old Oct 10, 2006 | 02:52 PM
white-88's Avatar
white-88
St. Jude Donor '06
Default Man, I need help BAD !!
Please, Can someone help me?
The last time I drove my '88 was 2 weeks ago. She ran great. I put it in the garage, cleaned it up and went inside. Next morning I go to start it and it won't run!. as soon as I put the key in, the fan started running. When it did kinda run, very bad, for about 45 sec., lights on the dash were going crazy! Even shift light. I have an auto ! I ran the codes and came up with a code 22,32,and42. I don't get it? it was fine when I parked it. I'm really in a bind. I live in the middle of nowhere so there is not even a shop around here!
Thanks guys!!!
Old Oct 10, 2006 | 04:49 PM
RRT vette's Avatar
RRT vette
Did you wash the engine bay before putting it up? PM sent.
Old Oct 10, 2006 | 05:36 PM
white-88's Avatar
white-88
St. Jude Donor '06
no , all I did was dust the outside, and inside .
Old Oct 10, 2006 | 05:40 PM
RRT vette's Avatar
RRT vette
Pic of the EST location:
Old Oct 10, 2006 | 08:06 PM
RRT vette's Avatar
RRT vette
Try and solve the codes starting with the lowest number first. Check the connection x2 and make sure the wires are in good shape. Follow the FSM code troubleshooting steps to solve this. Sounds odd that all this happened out of the blue. Work on it and see what you come up with.
Old Oct 11, 2006 | 04:00 AM
Casethecorvetteman's Avatar
Casethecorvetteman
With the TPS, EGR and EST codes like that its probably going to be a loose ground or a short somewhere. Check the connections at the ECM to make sure they are all nice and tight. Clear the codes and try again, and see which ones you get straight up.
Old Oct 16, 2006 | 06:25 AM
RRT vette's Avatar
RRT vette
Have you fixed the problem yet?
Old Oct 16, 2006 | 10:19 AM
white-88's Avatar
white-88
St. Jude Donor '06
I bought a basket of parts. but didn't work on it yet. But get this ! Last night, my wife TOLD ME lets push her back and then over in the garage so so she can have the garage again !
Old Oct 17, 2006 | 04:38 AM
RRT vette's Avatar
RRT vette
Yeah I make my wife sleep in the garage too. J/K.
Let us know if you need help.
Old Oct 17, 2006 | 06:40 AM
Casethecorvetteman
And im still single thank christ...
To Man, I need help BAD !!
