Starts then dies immediately UNLESS gassed
Old Oct 11, 2006 | 02:32 PM
runner140*'s Avatar
runner140*
ALL of the above AND check for a clogged fuel filter.
Old Oct 11, 2006 | 02:44 PM
Staehling's Avatar
Staehling
Fuel filter is quite new, and fuel pressure is good and stays good when coaxed at pseudo-idle, but will check if gas/egr/iac don't fix it.
Old Oct 11, 2006 | 02:54 PM
RRT vette's Avatar
RRT vette
I believe your problem is the IAC. Also check the TPS voltage. I don't believe the EGR is at fault.
IAC is IDLE Air Control. As long as the throttle plates are closed the IAC helps contol the air entering the intake and is controled by the ECM. If it is cabon filled it will not work properly and will not throw a code. Take the TB off and the IAC out and clean them both with throttle body cleaner. Install the IAC with the tip of the pintle no further than 1 1/8" from the flange. Make sure the TB and IAC gaskets are good or replace.
The TPS sends voltage to the ECM according to the throttle blade postion. It should be .54v at closed throttle blade and 4v+ at WOT blades.
The EGR is not active at idle or WOT. Although there could be a vac leak. The solenoid is grounded frequently by the ECM when accelerating or cruising.
Old Oct 11, 2006 | 03:01 PM
mikey whipreck's Avatar
mikey whipreck
The EGR is active at idle if it's malfunctioning (check your FSM... in section 6e3 I believe).
My EGR solenoid is acting like its getting throttle all the time. The manual states that in that situation, if the car is able to idle, it will idle like crap (although it phrases it a little nicer).
EDIT::::
page 6e3-118 (at the bottom) lists symptons, and 121 is the flow chart
Old Oct 11, 2006 | 03:07 PM
RRT vette's Avatar
RRT vette
I guess if the solenoid was malfunctioning it could cause a problem at idle, but would usually let you know with a code. I'll read that.
Old Oct 11, 2006 | 03:09 PM
mikey whipreck
Nah no code... in fact the flowchart for troubleshooting the solenoid specifically states, to only use the flowchart if a problem is suspected, and no code is present.
It's something I didnt' realize until about a week ago... hell, 2 weeks ago I didn't even know what an EGR solenoid was. I believe Vader86 helped me out with that.
Old Oct 11, 2006 | 07:56 PM
Curveit's Avatar
Curveit
My car started to do this one day; would not idle. Check your "coolant temprature sensor" in the front of the intake manifold. My connector was bad, and it wasn't making good contact. I was getting a code "34" and I replaced my MAF needlessly. ( Well, It was 20 yrs old)
Old Oct 11, 2006 | 08:49 PM
RRT vette's Avatar
RRT vette
If no luck with the ones stated above, you can check this sensor. Located in the front of the intake manifold. Yellow and black wires on my 86. Make sure the connection is good and the connector looks good. The sensor itself can be ohmed. It is a temp resistance sensor that the resistance increases the colder the engine is and vise versa. If you ohm it take the number and take the temp of the engine and post back to see if it's in normal limits.
Old Oct 11, 2006 | 10:11 PM
Staehling's Avatar
Staehling
can't express the relief I'm feelin now
fixed with the idle stop screw, will post details after dinner!
Old Oct 11, 2006 | 10:17 PM
RRT vette's Avatar
RRT vette
Great to hear. Remember when you turn the minimal idle screw (I assume you mean the screw on the drivers side of the TB) you have to recheck the TPS voltage because when the blades are moved so is the TPS voltage. You may need to set the minimal idle now. Vader86 has a website in his profile that explains it or look HERE.
Also I wouldn't hesitate to still remove the TB and IAC for a good cleaning.
Old Oct 11, 2006 | 10:40 PM
Staehling's Avatar
Staehling
TB cleaned very recently, will readjust TPS asap!
I followed the FSM procedure with all the steps for minimum idle adjustment, so should be good.
Short version of all this is that while I was hunting for the cause of my post-tuneup miss/stutter, I was manually moving/holding the throttle mechanism a lot while peering into the engine. Only thing I can come up with is that I must have tweaked something there such that the idle screw(which had never been touched in 19 years) needed to be screwed in a bit for minimum idle to not sink too low.
Old Oct 12, 2006 | 12:47 AM
cplonner's Avatar
cplonner
I had this same problem and the maf unplugging test didnt work but when I actually replaced the maf it started right up.
One thing would try if you havent already is just unhook the negative terminal to the battery, let it sit more a couple minutes, reconnect it and try to start it again. That actually works somtimes.
My guess is somewhere with the maf or the tps. Thats where I was looking when I was fixing my prob.
Old Oct 12, 2006 | 08:40 AM
  #33
mikey whipreck
Good to hear. Easy and free fix
Old Oct 12, 2006 | 11:23 AM
  #34
Staehling's Avatar
Staehling
Thanks - was feeling pretty down the other night, so cheers to all who gave great suggestions, it psyched me up to tackle it again and finally nail it.
