Dash Bulbs
Old Sep 16, 2001 | 04:15 PM
tsquare's Avatar
tsquare
Default Dash Bulbs
How many bulbs are there for the the gauge cluster,tach,speedo.And are they all 882 bulbs?
Old Sep 16, 2001 | 04:19 PM
vader86's Avatar
vader86
Default Re: Dash Bulbs (tsquare)
four main bulbs that you can change, all the same
Old Sep 16, 2001 | 10:09 PM
jfb's Avatar
jfb
All 882's
Old Sep 16, 2001 | 10:12 PM
GRX's Avatar
GRX
Don't forget: Do not touch the bulb glass with your fingers. Use long-nose pliers with some electrical tape wraped so you don't crush the bulbs. Good luck!
Old Sep 16, 2001 | 10:25 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
4 is correct,i used the 194's.
These are cheaper and not quite as hot,I think it is 1.5
candlepower less than the 882's.
Oh ya,i agree do not touch the bulb--oily fingers.
matt
Old Sep 17, 2001 | 01:07 PM
jfb's Avatar
jfb
fingerprints on quartz iodine lamps can weaken the glass because it gets so hot, but 194 lamps are not quartz iodine and you can handle them with your fingers without any problems.
To Dash Bulbs
