Ign.module connections
Old Oct 13, 2006 | 11:11 AM
white-88's Avatar
white-88
St. Jude Donor '06
Default Ign.module connections
I was doing the cap and rotor on the'88 , so I thought about replacing the module as well. I look at it and the connections for the 5 wires is broken. it is still attached fine , but the top piece of the plug in is broken so I didn't touch it. Will this still work will it short out?
Old Oct 13, 2006 | 11:55 AM
rick lambert's Avatar
rick lambert
Just a matter of time before it gives you problems or leaves you stranded....I replaced mine.
Old Oct 13, 2006 | 12:05 PM
white-88's Avatar
white-88
St. Jude Donor '06
Where can you buy the new connectors?
Old Oct 13, 2006 | 01:00 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Try NAPA. They carry a variety of sensor and electrical connectors.
Old Oct 13, 2006 | 01:50 PM
white-88's Avatar
white-88
St. Jude Donor '06
Thanks !! I am going there today anyways !!
And as always Thanks everybobdy !
Old Oct 13, 2006 | 05:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
www.tpiparts.net
Old Oct 14, 2006 | 10:01 AM
RRT vette's Avatar
RRT vette
Yes, replace it. Did you figure out the code you were getting the other day?
Old Oct 14, 2006 | 10:55 AM
white-88's Avatar
white-88
St. Jude Donor '06
Not yet. But I'm going to work on it today. I bought a new module and computer.
Old Oct 14, 2006 | 11:13 AM
rick lambert
I had to get mine at the Stealership...
To Ign.module connections
