electrical gremlin
Old Oct 13, 2006 | 09:03 PM
Yellow2015's Avatar
Yellow2015
Default electrical gremlin
OK gurus............I have an odd one here but first a few stats:
88 coupe
battery is just shy of 2 years old
alternator is less then a month old
car is only used on weekends
the gremlin:
After installing the new alternator I noticed that when I first start the car after it sits overnight, my dash voltage reading is 11.2 and the battery light comes on. If I run the car for about 2 minutes it climbs right back up to 13.3 which is normal. Last week I used a battery charger on it overnight but the dash still read 11.2.
This week I let the car sit for FIVE DAYS and tonight, before starting it I put my voltmeter on the battery and it read 12.9 yet the dash read 11.2 with the light coming on. It can't be a parasitic drain because after 5 days the battery should have been dead. At the vert least it shouldn't have read 12.9.
any ideas???????
Old Oct 13, 2006 | 09:44 PM
Da Mail Man's Avatar
Da Mail Man
88 coupe
the gremlin:
any ideas???????
......remove the battery and have it load tested as it sound like there are problems..also, after you start your car, place a volt meter on the hot wire at the alternator and tell us what the voltage is...may be a bad voltage regulator....
Old Oct 13, 2006 | 10:54 PM
Yellow2015's Avatar
Yellow2015
The battery was tested under load. I will check the hot wire from the alternator tomorrow............ The one thing I didn't check. DOH!!!!!!!!!!!!!
Thanks mailman....
Old Oct 14, 2006 | 12:02 AM
jfb's Avatar
jfb
The dash voltmeter reads low if the engine is not running! Measure the battery teminal voltage when you start the engine, it should measure close to 14.7 volts. The battery symbol light comes on when the alternator is not charging the battery. Engine running, measure the voltage across the battery and the alternator output, it should be the same. If the alternator is 14.7 and the battery is below 13 volts, then you have a blown fusible link in the alternator output wire.
Old Oct 19, 2006 | 06:17 PM
Yellow2015's Avatar
Yellow2015
Ok, heres what I have. The car has sat idle since Sunday. The battery voltage with the car off today was 12.9. The alternator was the same. I started the car and maintained the same voltages at both the battery and alternator but the dash read 11.8. After a minute or so the battery light came on. I let the car idle and the dash reading eventually went up to 14.2 but the battery and alt stayed at around 12.9.
The car started fine and the voltage was the same at the battery since monday so I know there's no drain on the system.
Old Oct 19, 2006 | 07:05 PM
Da Mail Man
EDITED..i think your alternator is history....
Old Oct 19, 2006 | 07:46 PM
Yellow2015's Avatar
Yellow2015
Well since it's only a month old, I'm sure I'll have no problem returning it.
Old Oct 19, 2006 | 07:49 PM
Da Mail Man
.....i had one like that many years ago which took 10-20 seconds to product "decent" voltage......took it back under warranty and all was well....
Old Oct 21, 2006 | 11:42 AM
Yellow2015's Avatar
Yellow2015
All the planets are now aligned correctly...........it WAS the alternator......
Old Oct 21, 2006 | 11:44 AM
Da Mail Man
........i thought so!......SPIKE THAT FOOTBALL!...END ZONE DANCE!
To electrical gremlin
