Door carpet seperation
The tech service bulletin says to use 3M trim and emblem adhesive.
( available in tube or aerosol spray)
It can be done with the panel installed on the door but you have to be carefull not to over apply the glue (or it oozes out) and hold the carpet in place until the glue tacks up.
The better way is to remove the door panel, lay it flat, apply the glue and use something flat and heavy to hold the carpet in palce while the glue sets-up
Thats what I did with mine.
