What does a Dana 44 look like?
Old Oct 14, 2006 | 10:48 AM
BLWN BUX's Avatar
BLWN BUX
Default What does a Dana 44 look like?
Hi:
I have an 89 conv. that is set up with :a S.C. 383, Stall conv., Built trans, and several other mods.
I want to know if it has a D44 or a D36. The rear end was changed by previous owner to install 3:73's.
I want to do a little drag racing. i am told that the D36 will not live if I put on some Drag Tires.
Thanks for the read
BLWN BUX
Old Oct 14, 2006 | 10:52 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
They look similar but the 44 is a bit larger and also has one less cover to case bolt. I used to have a link to a picture of them, if I can find it, I'll post it here.
Old Oct 14, 2006 | 11:28 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Old Oct 14, 2006 | 11:35 AM
Corvette Kid
Originally Posted by Mr Mojo
I couldn't find my link, I think it's gone. I was just getting ready to PM you and ask you if you'd post that.
Old Oct 16, 2006 | 09:20 PM
BLWN BUX's Avatar
BLWN BUX
Bummer, I have a D36
Any body know how much power the D36 will withstand?
I wan to run drag radials, but the drag race guys tell me it will gernade.
This is subjective of corse, But I expect to be making over 500RW once I install my new T trim. I am only at 400 now with the Paxton ball drive S.C.
Thanks for the images
Chad
Old Oct 16, 2006 | 09:46 PM
Cold_B's Avatar
Cold_B
I would imagine that with a good launch you could kill it right now. Some people seem to kill them easier than others, but if I were you, unless I was ready to spend the money right now to change it, I would be careful on the launches.
Old Oct 16, 2006 | 09:50 PM
Mr Mojo's Avatar
Mr Mojo
Mine broke with a stock LT1 and street tires.
Old Oct 16, 2006 | 10:16 PM
BLWN BUX's Avatar
BLWN BUX
What years/ models had the D44 if I was to seak?
I like my 3:73, but I guess that there are some 3:54's out there?
Old Oct 16, 2006 | 10:29 PM
Siveck's Avatar
Siveck
The D44 came with a manual transmission from '85-'96. My '89 convertible has the D44 and 3.54 gears from the factory.
To What does a Dana 44 look like?
