Thanks Bogus, the cats fairly new 1-2 years, tune up and 02 about 1 year old, past due on oil change, PVC about 1 year old. What I was kinda wondering about is the air duct between the MAF and TB, it's got 2 big cracks. Been ideling an running ruff..low on power.
Did she drive it around and get it to operating temp, or drive it down the block and right into the test center? Just reread the post. Cracked duct between the MAF and the TB would cause added air, plus sucking in dirt.
Fix that soon and retest, I suggest.
If I understand the failure as high HC at idle speed and the idle is rough I would look for a misfire. Definitely look at the cracked MAF hose but also verify the plugs and wires are okay, good luck.
Thanks Guys, I'm gonna help her repair the duct. She's got a Chiltons POS, but I'm also gonna check for codes, check the plugs and have her get her oil changed.
make sure you put fresh oil in her, before you test also I sometimes add some denatured alcohol to the tank or some cleaners few days before also to clean her out .....and check the plugs if its not a pain to get at not in this order though
HCs (hydro carbons) are unburned gasoline. A rich mixture causes high CO. The HCs can be high, too if not all the extra gasoline is burned. A too lean mixture, can cause a "lean misfire" that will leave unburned (HCs) gasoline.
Rick, I'm no emissions guy, but from what I have read in some of my books, the web, and here..it is running rich. We don't have emmissions testing here but my Dodge with 255,xxx miles I'm sure would fail even though it runs good. You know what things could make them run rich and the cracks in the air duct would be a first fix. As you know the "running ruff and low on power" could be a cylinder misfire (unburn fuel), leaky injector(s), or O2 sensor..to name a few. I'd be nice if you could plug it up to your scanner.
You catch on quickly. HCs are the unburned gasoline molecules. If the mixture is too lean to burn, the unburned molecules show up in the exhaust and are measured by a smog machine as HCs, because gasoline is a hydro carbon. That is why changing your oil before a smog test, helps. If there is gasoline diluted in your oil, it may not all burn, and cause you to fail for excess HCs. I once failed on HCs because an overactive EGR valve leaned the mixture and caused a lean misfire resulting in high HCs.
Originally Posted by bogus
Lean misfire - not enough fuel to burn, but enough fuel to raise the HC's?
You bet your sweet... The A/F ratio as to be in the proper range to ignite. But it doesn't take much unburned fuel to screw up a smog test.
Lean misfire can really get tricky from the diagnostic standpoint since a misfire also introduces a large amount of oxygen into the exhaust, when the O2 sensor "sees" the high oxygen content it commands wider pulse width.
One key as CFI-EFI pointed out is that high HC indicates incomplete combustion or misfire, high CO indicates a rich mixture. 5 gas analyzers can help diagnosis by reading O2 and CO2 at the tailpipe, the lean misfire condition would have high O2 and low CO2.
Stuck open or overactive EGR as CFI-EFI said, plugged or inoperative injector are possible causes of lean misfire.
Thanks guys this comming weekend we'll get it in my garage..fix the duct work, pull the plugs (with this many miles) they may be foulded, check the 02 sensor and change the oil. I'm gonna check the fuel pressure and see if there's any stored codes.Clean the MAF sensor connections and see what happens.Thanks again.
