Air pump delete in a 84..
Old Oct 16, 2006 | 05:54 PM
elkabong's Avatar
elkabong
Default Air pump delete in a 84..
Can someone tell me if the air pump eliminator thingies will work with a 84?
Old Oct 16, 2006 | 05:56 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
no clue... but now im curious
Old Oct 16, 2006 | 07:34 PM
CFI-EFI's Avatar
CFI-EFI
They might, but why would you want one. Is the wallet getting too thick? Are you starting to sit at an angle from the wedge on one side? Pull the pump off and install an 85" belt. Then send me half the money I saved you by not buying an unneeded kit. There is no pulley replacement necessary to eliminate the A.I.R. pump, on an '84.
RACE ON!!!
Old Oct 17, 2006 | 09:37 AM
elkabong's Avatar
elkabong
Thanks for the info. Would you happen to have a part number I can give to the parts counter person? I prefer to give some extra cash to charities... If you are telling me you are a charity case we may be able to do something.
FWIW - I asked a simple question and a simple response was all that was necessary. The rest of your response... well nevermind.....
Old Oct 17, 2006 | 11:07 AM
redrose's Avatar
redrose
the air pump elim/ alternator relocation brackets that were used on my 86 ''probably'' will fit the 84, has not been tried/proven yet...the primary mounting points are the same...minor alternator differences may req length change of rear alt brace...new, shorter serp belt length can be estimated, expect a return to parts supplier to swap for exact length
Old Oct 17, 2006 | 11:38 AM
CFI-EFI's Avatar
CFI-EFI
Of course I have a part number. FWIW - I gave you the answer to the question you asked. As for your second question... well nevermind.....
Forget I responded. Follow redrose's advice.
RACE ON!!!
Old Oct 17, 2006 | 12:00 PM
elkabong's Avatar
elkabong
CFI - you miss the point. All I am stating is a simple question deserves a simple answer. I don't need to read, and others don't as well, the part about my wallet getting too fat etc etc etc. The purpose of this forum is to share info and get info. Not deal with personal nuances or attitudes..... I guess today I get the ire of the almighty "CFI-EFI"... I am honored.
Moderator..... please delete this post it is not worthy of taking up diskspace.
Old Oct 17, 2006 | 12:05 PM
kopbet89c4's Avatar
kopbet89c4
CFI-EFI is quite a character. With that attitude, you either love him or hate him. Must have been another bad day at work or just male PMS.
Old Oct 17, 2006 | 12:23 PM
mk842766's Avatar
mk842766
Well,,,when you ask stupid questions???????WTF do you expect when you choose to ignore a perfectly appropriate answer, and you choose to ignore it
Old Oct 17, 2006 | 12:42 PM
JLeatherman's Avatar
JLeatherman
Elk,
I am fabbing a bracket to move the alternator an inch or two higher. If you do this you don't need the air pump emilinator. I believe that if you try an 85 belt without moving the alternator higher you will be too close to the power steering pump pulley.
Old Oct 17, 2006 | 01:05 PM
Supernatural's Avatar
Supernatural
For an 1984 you will have to relocate the power steering resevoir. You can make a bracket, strap it to the eliminator pulley bracket or use the 1985 style resevoir bracket. The 1985 bracket is discontinued from GM-you will need to find it used.
To Air pump delete in a 84..
