I was curious what tool everyone is using to balance their TB's on their 82-84 vettes. I currently am using the normal yard stick and plastic tube model. Purchased all parts from home depot for a few dollars. Took about 3.5 minutes to build. Works well, but im still not convinced its a perfect tune.
I have been pricing Digital manometers on ebay and was wondering what everyone else uses. Anyone using a digital unit? Likes dislikes? Any advice for me as I plan to purchase one in the near future.
Discuss!
Ok,I've never actually balanced my TB's with a manometer and they shouldn't ever be out of factory sync unless something is bound up,bent or damaged.
I've had my TB's bored to 2" and just used a feeler gauge to get each throttle blade closed as close as possible. I used a .0015"-.0020" gauge to just barely creap by the throttle blades. A piece of paper works well too. They are about the same thickness aswell.
If your TB's are adjusted the same and there is still driveablity issues then try somewhere else. I've had the TB's blades pretty far off before from each other and it still ran the same to me.
The motor was rebuilt on the car about a year ago now. I have slowly been making changes to the fuel system ect. I have read that everytime the TB's are removed from intake, they should be rebalanced to assure they are in sync. GM balanced these cars using a manometer. Your technique is one I have heard of, and even seen mechanics use. I still would like to know about the digital meters though.
Balancing is pretty important for a nice smooth idle. I picked up an analog manometer gauge on eBay with a 3/8 npt fitting and I plumbed it to a vacuum line with hardware store parts. It works great. Just search around for a 0-15 or 0-30 inches of water vacuum gauge.
Feeler gauge here too. Never had any problems with em' being out ever with my 2"TB's or stock ones. Its ok to use a gauge. The 6026 ecm in our 84's is so stoneage it won't make a huge difference unless they are way off Vacuum leaks are the main cause of issues with our cars.
My advice is.....if the TB's are all original try to rebuild yourself with a GM parts rebuild kit. check your thottle shaft for play. The IAC port can get extreemly dirty and carboned up along with the IAC's springy thingy gets nasty too.
I cannot address your "perfect tune", but you have built the perfect manometer, to adjust it with. A digital manometer would be a colossal waste of money. Before I spent the massive amounts of money at the hardware store and invested the 3.5 minutes to build one, I decided to give it a shot, without one. At the barely running minimum air idle speed, I started playing. I was absolutely amazed at the difference in the smoothness of the idle, when the TBs become matched (synchronized). The (home made) manometer is a great tool, but think about what you are trying to accomplish. The ear is the better tool. As for feeler gauges... they'll get you to a good starting place.
Discuss!
I would't spend the money for a digital meter. I bought a couple of Dwyer "magnehelic" gauges off eBay. They were cheap, and are quite accurate. They come in lots of different ranges.
