Inside wheel sensor question
Old Oct 17, 2006 | 11:32 AM
spinedoc's Avatar
spinedoc
Default Inside wheel sensor question
I need to re attach the air pressure sensor inside the wheel on my 96 LT4. I am removing it tomorrow. Can anyone tell me how they attch tot he wheel?
Thanks.
Old Oct 17, 2006 | 01:47 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
its more or less a band on the inside of the wheel with the sensor attached to it. You will need to take the tire off the wheel to get to it.
Old Oct 17, 2006 | 10:01 PM
95BLKVette's Avatar
95BLKVette
The sensor sits opposite the fill valve just inside the exterior rim (ie. if the tire is oriented so that the valve is on the bottom of the rim, the sensor is on the top).
Make sure the tire guy knows about this or the tire removal iron will shear off the sensor case
Ther originally was a rectangular decal on the rim where the sensor resides inside, but usually they have worn off.
To Inside wheel sensor question
