Need some help
Old Oct 17, 2006 | 12:14 PM
honda hunter's Avatar
honda hunter
Default Need some help
Can someone look at my tune to see if there is anything wrong with it or anything out of place? Int the thread below I state the issues Im having and I want to be able to rule the tune out.
http://forums.corvetteforum.com/show....php?t=1526124
Old Oct 17, 2006 | 01:46 PM
VenkmanP's Avatar
VenkmanP
Remind us again - exactly which parts did you use from the 94 and which from the 93?
Old Oct 17, 2006 | 01:55 PM
honda hunter
I reused everything that was on the 94 except the fuel rail. Had to reuse the 93 fuel rail because the 94 camaro fuel rail couldnt be used. I had to stick with the 93 ecm and wiring harness for now.
Old Oct 17, 2006 | 02:00 PM
VenkmanP's Avatar
VenkmanP
Is there any way to hook it up with the 94 PCM?
Since it was working well with that before, seems like that would be a good way to determine if it is the engine/install or the tune.
Old Oct 17, 2006 | 02:05 PM
honda hunter
Actually I found a 94 PCM and harness for sale from a Camaro I want to use. I assume all I would need is a maf and all would be well correct?
Old Oct 17, 2006 | 04:42 PM
VenkmanP's Avatar
VenkmanP
You don't need a MAF, but if the purpose is to test it with the exact same tune you had in the 94 car, then you'll want to use the MAF.
Injector harness is different - do you have the 93 or 94 harness on the engine now?
Old Oct 17, 2006 | 07:48 PM
honda hunter
93 right now.
To Need some help
