What are some of the benefits of after market torque converters. Anything other than upping the stall rpm? As stall goes up how much does driveability suffer for a daily round town driver? Just from reading bits and pieces, it seems like a torque converter upgrade might be one of the better bang for buck upgrades for a basically stock 86 z51 w/3.07 gears?? Anyone have some real number differences (times) from just a converter change out there? Arlon
From what I have seen, there is generally a two tenth gain in the 1/4, or more. I had a 3500 RPM in a turbo car before my current car and loved it. I'm going to a 2400 stall with this car. Driveability may be nicer, less pulling through the breaks. With a high stall DD the slipping would make driveability worse. Run a search, lots of info. out there.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
See my reply to cplonner's thread on the subject. Also, if you add a converter, add a cooler too. In fact, for longest transmission life, add a cooler no matter what.
Arlon,
86 vettes cam with a 2000 rpm stall converter. They are about the highest stalling vette converters made for a c4. Because of this, your car may only benefit a tenth or 2 in the 1/4 mile. You will appreciate it more(if you stay conservative) on the street than at the track. A looser converter lets a car idle smoother and accellerate quicker.
Since our 86s already have a 2026rpm converter anyway, there is really no need to upgrade. An upgrade to a smaller converter at a higher stall could give some small gain on a stock/nearly stock L98, but its not worth the total cost.
