LT1 has reverse flow cooling and provisions for the gear driven water pump and Optispark. I'm sure there is more, that's all I can think of for now. A Miniram from TPIS gives the L98 some of the same characteristics as an LT1 as far as looks and airflow.
Thanks guys. I knew the heads were different, due to the reverse flow, but was unsure on the block. Not doing a motor for myself. A friend asked about getting an LT 1 built and I was unsure if the block was LT1 specific.
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Switching from reverse-cooling to regular is easy enough to deal with. You'd need a distribitor that gives out the same signals as the opti.
Keep in mind that large bore blocks don't have cooling between the bores. Also w/o reverse cooling you can't run the compression so high, so efficiency is losted.
396ci ( or even cheap 383ci ) LTX's make a lot of power. You can make a 421 LTX but that's with a really long stroke, and a really bad rod to stroke ratio.
... You can make a 421 LTX but that's with a really long stroke, and a really bad rod to stroke ratio.
I knew there had to be some down side to this amount of cubes, ive never heard of anyone on here with a 421 LT1 yet, and ive always wondered why.
At one stage i was told its not do-able, which i know is garbage.
The electronics on the later C4s make this kinda swap nothing but hell... you would loose ABS and ASR... the CCM would have a cow which could effect electronic climate controls and such.
Personally, I would build a 383 and put a blower on it.
Oh, and if you live in a state that follows EPA/CARB, you would be in deep ****... the EPA rules expressly permit replacing an engine with same year or NEWER, but never older. And truck engines are not legal, because they had different standards for so very long.
Emissions aside for the moment. Bill Mitchell sells a 454 SB short block with 10.2 CR for around $4,500
Virtually all the parts off my 415 will swap over except, perhaps, the oil pan (due to the longer stroke crank). I've got the ECM and wiring harness, etc. off my 86.
All I'd need to do is strip my 415 of its power parts, re-install them in/on the 454 (retro-hydraulic roller cam and valve train parts, headers, water pump, etc.) then move to a free flowing set of heads, and plop down my MiniRam.
The wiring differences are, to me, the biggest challenge but I suspect someone has done it before.
The more I think on this, the more I drool.
Jake
That might be a tall deck block, in which case the intake would need spacers, and the distributor would need a longer shaft, not to meantion the headers may not fit. It may also be a raised camshaft block, meaning the timing chain and cover are also custom. You need to contact the manufacturer for details. It would be a nice swap.
Are you already running the 415 in place of the LTX?
No, the LT1 is still installed in my 96. The 415 is still in the 86 sitting out in front of the house.
Jake
BTW, the Motown 4 bolt block used in that build-up has standard deck height, doesn't call for any special valvetrain parts (no Jesel shaft system or off-set rockers, etc.), has a two piece rear main seal, blind head bolt holes and will drop right in to a Vette.
From what I've read the block can be bored larger than 4.2 and still retain excellent wall thickness. The only thing - at the time the article was written - was there was no ring set available to go as big as the block can be safely bored. That may well have changed by now though.
There was one reference to a 500 inch SB using that MoTown block, but I'd need to go back to re-read it to refresh my memory on the details.
