ECM location
Old Sep 17, 2001 | 11:11 PM
gbody5's Avatar
gbody5
Default ECM location
OK, this should be an easy one, where is the ECM located in an 88 Roadster?
Let the troubleshooting begin :smash:
Thanks,
Mark
Old Sep 17, 2001 | 11:25 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: ECM location (gbody5)
Mine is under the dash on the right hand side. Not real hard to get to if you are kinda flexible. Take off the plastic trim piece under the right dash, it has a little light built into it that you unplug when you get the panel unbolted. Then look up, you will see the wire harness/plug. It's a metal box a bit smaller than a cigar box.
Old Sep 17, 2001 | 11:32 PM
VetteRacer282's Avatar
VetteRacer282
It is above the passanger side underdash. Unscrew that footwell panel and you should see it. If I remember right, there are 2-4 screws to undo and the ECM will slide out (unhook connectors) from the tray.
Good luck.
Old Sep 17, 2001 | 11:40 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Invest in a Hayes or Hanes book. Very good investment...alot of pictures...very helpful...Good lunk!!!
Old Sep 17, 2001 | 11:43 PM
gbody5's Avatar
gbody5
Default Re: ECM location (VetteRacer282)
Thank you and thank you, sounds like a FASSSST and soon to be FASSSST Corvette you guys have!
Old Sep 18, 2001 | 12:30 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First open the connector in the orange wire near the battery to remove power to the ECM.
Three screws hold the bottom pannel and two hold the ECM. Slide it down and remove the two screws and the Al access pannel. Undo the two latches to pop out the CalPac. Press in the new CalPac and assure that the two latches are firmly in place. Reverse the above steps.
Careful not move around on the carpet once the ECM is opened up...static electricity is your enemy.
To ECM location
