Spring rate
Old Oct 20, 2006 | 08:31 PM
csiki22's Avatar
csiki22
Default Spring rate
What are the spring(stock) rates for
an 84 corvette.Thanks
Old Oct 21, 2006 | 08:06 AM
Slalom4me's Avatar
Slalom4me
Hib Halverson's suspension chart at CorvetteActionCenter.com
has a lot of information for C4's
From that chart, the 84 rates are
FE1 - _63.5/72.0 N/mm . (363/411 lbs/in)
Z51 - 102.0/87.5 N/mm . (582/500 lbs/in)
I use the following factor to convert to lbs/in
N/mm * 5.710 = lbs/in
Now, if it turns out that you really wanted to know what
the valve spring rates are in an L83 - I can't help you.
Old Oct 23, 2006 | 05:25 PM
csiki22's Avatar
csiki22
Default rates
Thanks thats the info I needed!
To Spring rate
