Oil Filter
Old Oct 21, 2006 | 10:33 AM
Corvette Chris's Avatar
Corvette Chris
Default Oil Filter
Headed out the door in a couple minutes to go pick up an oil filter to change the oil. After all the stuff I've heard and seen on Fram filters, I've decided to change. Cut to the chase -- what is the PH 30 equivalent on a Mobil 1?
Old Oct 21, 2006 | 12:15 PM
Corvette Chris
Does Auto Zone carry M1 filters? I went to Pep Boys about an hour ago, and they don't carry the sizes I need.
Old Oct 21, 2006 | 12:33 PM
bogus's Avatar
bogus
From your profile, you have an 86, right?
I use K&N Oil filters, mostly cause of the little nut (1") to help remove and install same.
K&N HP-2002 is the right one for an 86. For the M1 it's the M1-111. Both are normal stock items at Autozone.
You can also go to mobil 1 or K&N sites to confirm or xref any filter.
Old Oct 21, 2006 | 12:39 PM
Jerris's Avatar
Jerris
I use the K&N on mine with no problems.
Old Oct 21, 2006 | 04:04 PM
C4396roadster's Avatar
C4396roadster
I use the 1218 delco
Alan
Old Oct 21, 2006 | 08:34 PM
Ajaste's Avatar
Ajaste
The K&N filters can't be beat for ease of removal.
Old Oct 21, 2006 | 08:42 PM
tequilaboy's Avatar
tequilaboy
The Mobil 1 filters have changed recently.
I have a new one here, its an M1-111 Extended Performance. This was the recommended filter for my 88. It is considerably shorter than the traditional sbc filter ph30, pf25 etc, so I was skeptical when I bought it.
I haven't used it yet, but the short body should work for me since I have a header tube that runs under the filter making a normal filter somewhat difficult to install/remove.
Old Oct 21, 2006 | 09:07 PM
Sam Lam's Avatar
Sam Lam
on the K&N oil filter due to the anti-drain valve, superb oil filtering ability and ease of removal. However, they do cost more.....and they are worth it.
Old Oct 21, 2006 | 09:39 PM
Louis Bartay's Avatar
Louis Bartay
Go with a K&N it is worth the extra $5.00 just to have the nut on bottom
To Oil Filter
