95 LT1 OBD1-2 problems
Old Oct 21, 2006 | 01:35 PM
tm2k's Avatar
tm2k
Default 95 LT1 OBD1-2 problems
I am just about to pull my hair out(whats left) trying to get this OBD cable to pull data from my laptop.
I tried to make my own cable and was just getting junk data. My car is a 95 LT1 and is suposidly an OBD1 data stream with an OBD2 connector. I bought a premade cable and am having the same problem.
What am I doing wrong? The data stream is there but its just crap data.
What software should I use? I have tried countless programs and none of them have my exact vehicle, closest was a 94 LT1 Camaro.
Dave
Old Oct 21, 2006 | 04:01 PM
STL94LT1's Avatar
STL94LT1
I use Datamaster. You can download their software and get a free trial of 20 scans.
http://www.ttspowersystems.com/diagnostic.htm
Old Oct 21, 2006 | 07:11 PM
rickneworleansla's Avatar
rickneworleansla
I use datamaster also and tunercat for programming. I bought my usb cable from moates. Worked it's time no problems. A 95 with OBDI PMC and OBDII connector here also.
Old Oct 22, 2006 | 11:07 AM
tm2k's Avatar
tm2k
Thanks guys datamaster did the trick. I could not get any of the other programs to work but datamaster fired right up!
Thanks again.
Old Oct 28, 2006 | 06:26 PM
dc3plt's Avatar
dc3plt
I would also like to make my own cable. Where did you find the info. to construct??
Thanks alot!!
Mike
To 95 LT1 OBD1-2 problems
