Gap between distributor cover and firewall? (L98's)
Old Oct 24, 2006 | 10:18 AM
LWesthaver's Avatar
LWesthaver
Default Gap between distributor cover and firewall? (L98's)
I've noticed that a some L98's have a gap between the distributor cover and the rubber hood seal on the firewall. You can see it in this picture: (Credit: Bubba91's 1991 Vette)
And some don't. On my car (1985) there's no gap at all:
So I'm wondering, how does your L98 sit in its engine compartment?
Are the frame/engine/body tolerances really this sloppy on our C4's? Or is there some other explanation?
Old Oct 24, 2006 | 10:54 AM
Bad Karma's Avatar
Bad Karma
Just by looking at those pictures, the one cover looks longer.
Old Oct 24, 2006 | 11:06 AM
Steel Blue 91's Avatar
Steel Blue 91
Perhaps one is an aftermarket unit. Don't know which one that would be though.
Old Oct 24, 2006 | 12:02 PM
LS6 Motor's Avatar
LS6 Motor
The covers are the same, look at the weatherstripping, I would suspect that may be pushed over, or flattened more. It really isn't anything to worry about though. Here is a picture of mine, it has a fairly large gap, and that is the stock distributor cover.
Old Oct 24, 2006 | 12:05 PM
chucks88's Avatar
chucks88
It just looks longer to me
Old Oct 24, 2006 | 12:12 PM
Thrak's Avatar
Thrak
Mine is so far back that I cant get the cap out from under the weather striping.. I can BARELY get to the rear screws holding it down.
I'll take a pic when I get home tonight, but its pushed way back, even further than yours.
The carfax I pulled before I took ownership of the car indicated no accidents.
I was actually going to post this question soon as I know I need to replace the cap/rotor, but have no idea how I'm going to remove it.
Old Oct 24, 2006 | 12:14 PM
mikey whipreck's Avatar
mikey whipreck
You're comparing two difference engine types in those pictures.
Maybe that has something to do with it?
I have 0 gap on my '85's L98.
Old Oct 24, 2006 | 12:34 PM
chucks88's Avatar
chucks88
Speed Density vs. MAF...... I presume
Old Oct 24, 2006 | 01:39 PM
Skrud13's Avatar
Skrud13
Default Different Covers
I agree.....the covers are different. Look at the ribs on top and the length of the wings on the two covers. One is clearly longer than the other one.
Old Oct 24, 2006 | 01:42 PM
mikey whipreck
I meant Iron Vs. Aluminun
I had not even considered SD vs. MAF
Old Oct 24, 2006 | 02:10 PM
rick lambert's Avatar
rick lambert
Top looks like SD, next one looks like MAF.
Old Oct 24, 2006 | 02:52 PM
RRT vette's Avatar
RRT vette
They are different. One is a speed density and the other is a MAF engine. My 91 had the shorter distubitor cover. Where as my 86 has the longer one.
Old Oct 24, 2006 | 02:57 PM
mikey whipreck
nifty
Old Oct 24, 2006 | 03:35 PM
LWesthaver's Avatar
LWesthaver
I'm skeptical that the changes (SD vs. MAF, Aluminum heads vs. Cast Iron, etc.) made between the 1991 and the 1985 (mine) account for the difference in the gap.
I'd also be surprised if there were two different distributor covers (though it is possible.) Could a Chevy parts guy could determine if there were actually two different covers?
FYI, the length of my distributor cover is 6 5/8" from front edge to back edge. Does anyone have a shorter cover?
Old Oct 24, 2006 | 03:38 PM
Thrak's Avatar
Thrak
Originally Posted by LWesthaver
FYI, the length of my distributor cover is 6 5/8" from front edge to back edge. Does anyone else have a shorter cover?
The thing w/ that is, even though there might be a longer or shorter cover, our distributor is still pushed further back compared to the others...
Like I said earlier, my 85's distributor is so far back against the firewall, I'm not sure how I'm going to remove it... and thats independant of the cover length.
Old Oct 24, 2006 | 03:51 PM
LWesthaver's Avatar
LWesthaver
Yep, my distributor cap was also real difficult to remove because it is so close to the firewall.
The only other thing that comes to mind is the possibility that the engine is tilted backward due to a loose "C" beam??? My understanding is that the engine/transmission assembly is supported at three points, the left and right engine mounts and the transmission tail mount (in our case the "C" beam.) If the "C" beam was letting the transmission droop, then the distributor would tilt towards the firewall. The trouble is, I don't have any symptoms of the "C" beam being loose.
Still, I would like to hear from more L98'ers about the distributor cover to firewall gap.
Old Oct 24, 2006 | 04:00 PM
LWesthaver's Avatar
LWesthaver
Originally Posted by KODAVETTE
...look at the weatherstripping, I would suspect that may be pushed over, or flattened more...
It could be that the hood seal on my car has pushed over due to age. And I suppose that could account for the lack of a gap on my car. I'm going to take a closer look.
...Nope, just checked it. The rubber hood seal is where it's supposed to be, not deformed in any way. So that's not it.
To Gap between distributor cover and firewall? (L98's)
Old Oct 24, 2006 | 04:22 PM
jimmy_43's Avatar
jimmy_43
Cruising
Default Clean engines!
What are you guys using to clean your engines? They look great!
Old Oct 24, 2006 | 06:37 PM
tm2k's Avatar
tm2k
I asked our parts guys and the part # of 10108425 was the same for years 85-91 and is described as....Extension, intake manifold plenum.
Hope it helps.
Old Oct 24, 2006 | 07:40 PM
CorvAdel's Avatar
CorvAdel
Yeah....I have found the same thing....their are differences in distance from the dizzy cover to the w/strip.
The differences don't just stop there.
The actual rear of the engine.. block, heads, intake, are closer to the f/wall on some cars than others.
On one 86 while fitting the engine, I had another 86 in the w/shop and was referring to it regularly as I was having trouble getting the engine to fit!!
Sure enough, after it was finally in, I realised that there was a significant difference in distance from engine to f/wall between the two cars.
After taking measurements under the cars, esp. of the relative positioning of eng. mounts, I came to the conclusion that the bodies are mounted slightly differently.
In other words, the cars with the "small gap" had a body mounted further forward on the chassis than the other.
My understanding is that there is no difference in size of cyl. heads, blocks and dist. covers between L98's..
There is, however, a significant difference in how bodies are mounted.
This might explain why there is so much adjustment available for doors, hood and front bumpers..!
