89 6sp trans ??
Old Oct 24, 2006 | 05:26 PM
89 REDRUNNER's Avatar
89 REDRUNNER
6th Gear
Default 89 6sp trans ??
I'm pretty new here, have an 89 coupe 6sp-61k. At idle in neutral with clutch out, I hear a very very slight knock/roar. Car shifts out great and has plenty of power with no hesitation. Was wondering about a normal service/fluid change to start with, but want to be careful. Any thoughts or recommendations.
Old Oct 24, 2006 | 05:29 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dual mass flywheel, they make noise.....Bet it makes a little noise as you shut it off, too right? I have 80k more miles than you on an original and it still works well.
I wouldnt worry about it
Old Oct 24, 2006 | 09:55 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Its perfectly normal. But since you don't know the maintenance history it's a good idea to change the fluid anyways. There's a few options for what lube to use, but do NOT just pick up some random gear oil off the shelf.
To 89 6sp trans ??
