what coil does the vette take?
Old Oct 24, 2006 | 08:23 PM
Arlon's Avatar
Arlon
Default what coil does the vette take?
I have an accel super coil #140003. It says for basically every 4,6,8 cyl gm hei product car or truck from 1974-1987 EXCEPT corvette? What's up with that? What makes the corvette coil different? Is it just a space problem with the coil cover (missing from mine) or is there a REAL difference in the cap/coil for a corvette? Thought I'd use the super coil instead of having it collecting dust in the garage then I see the except corvette note... Drat.. Arlon
Old Oct 24, 2006 | 09:12 PM
Pete K's Avatar
Pete K
If the colors of the wires on the accel match the stock coil colors, it will work. There were 2 possible combo's. Red and white or red and yellow.
Old Oct 25, 2006 | 12:47 PM
Skrud13's Avatar
Skrud13
Default What about it if they don't match??
I recently bought a Hypertech coil/cap/rotor kit (part # 4052) and it all comes put together. I took the cover off the coil and noticed that the wires under the cap are red and yellow and the ones coming from my wiring harness are red and white. The summit site said this was good to go and the Hypertech site says the same. I haven't started it up yet because I am still rebuilding the motor, but now you have me wondering......is this going to be a problem?
Old Oct 25, 2006 | 01:38 PM
Wheelman's Avatar
Wheelman
Fire it up and report back to us.
Old Oct 25, 2006 | 01:48 PM
CFI-EFI's Avatar
CFI-EFI
It will run, but due to the reversed polarity, the spark may not be as hot for those tough firing situations. Either get the correct coil, or you can "crutch it" by getting a wrong ignition module with wire colors to match the wrong coil. Good luck replacing just one, next time.
RACE ON!!!
Old Oct 27, 2006 | 12:49 AM
Skrud13's Avatar
Skrud13
Default Works fine
Got it all buttoned up and started and no problems......works great.
To what coil does the vette take?
