Nitrous plugs
Old Oct 24, 2006 | 10:01 PM
DVS 99's Avatar
DVS 99
Default Nitrous plugs
I have an 88 with 383 stroker, AFR heads, Miniram intake, TPIS headers, 3.73 rear, ect. Car was built for nitrous (custom ROSS pistons, ring gaps, etc). About to put a 150-200 shot of juice on it. Just wondering what spark plugs you guys are running with your nitrous applications.
Old Oct 24, 2006 | 10:58 PM
STL94LT1's Avatar
STL94LT1
I would run NGK TR6.
Old Oct 25, 2006 | 02:03 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Default Projected Tip vs Standard
For nitrous you are better off with a non-projected tip plug.
NGK BR7EPS is a taper seat non-projected tip plug (.708" reach). If your heads require the gasket seat then take a look at NGK BR7ES which is also a non-projected tip plug but .775" reach and 13/16" hex. Attached photo shows projected vs. non-projected tip plugs.
Old Oct 25, 2006 | 08:21 AM
DVS 99's Avatar
DVS 99
Thanks guys will do a little more research now that I know a bit more.
Old Oct 26, 2006 | 06:38 PM
dbaker's Avatar
dbaker
Lot's of my buds run the Zex plugs.
\db2
Carolina
From the C4 side of life.....
To Nitrous plugs
