My son's '87 Coupe, the vacume controlled water valve located near the firewall on the right side of the car. The valve is leaking. The valve is integral to the supply and return lines, hard pipe for about 1.5 feet with some bends. I don't think it would be hard to plumb in a vacume valve with some 5/8" heater pipe. The question I have is about the crossover that seems to be under the valve. It looks to me like if the valve is in the closed position it diverts the hot water back through the return line. I think this might be needed since this is a Z51 car with the Modine oil/coolant oil cooler. Anybody know of a vacume water valve that has that bypass capability? Dealer has discontinued the part, and all the Vette part suppliers I've checked also have. I'd rather get the exact replacement but don't think I can. Thanks for any help.
One other question about this. There is a small coolant line running from the coolant supply line to the rear of the intake manifold, just to the right of the distributor area. Is that important? I don't have that on my mini-ram car so I just capped it off on the pipe on mine.
But you don't live in Minnesota. I've seen 2 degrees on the outside temp display on mine. I never managed to get the car out on below zero days but I wonder if GM programmed a minus into it.
I'm just about to replace the valve with a coupla ball **** valves from the hardware that can be manually opened and closed. Then in the spring and fall they can be left open and during the hot months they can be closed to prevent water from going to the heater core.
What does Minnesota have to do with anything? Do you think you have a patent on cold? Hoses replace where my water control valve for the heater used to be. The heater isn't bypassed, just the valve is. You complain when you get no responses, then you slough off one of value, when it DOES come along.
I think he might have got a little confused, I know when I read it I did. not untill I read the last post you did that I knew what you mean. not to defend or start anything just something I noticed. Where is this valve and how hard is it to bypass.
As per my genuine GM Corvette parts book, "VALVE, HTR WAT SHUTOFF". It is located on the right side of the engine, very close to the firewall. It uses short hoses to connect to the heater core pipe nipples. Maybe yours is bypassed, too. They were only used from 1984 - 1987. The 1984 and 1985 used unique part numbers. The 1986 and 1987 shared a third number.
There is no heater control valve on mine, the heater core gets water full time. If you want to use the valve you could try 'vette salvage places. I ran new heater hose with mine, the stock hoses were in pretty bad shape and getting a new stock hose was funny in cost.
Goodness CFI. Yes, when I read your reply and saw you said you haven't had a heater, and then you put a comma in. That made me think you don't have a heater, or water control valve. Sorry very much for my terribly abusive response about living in MN. I know I can just pipe on by the valve, but that would mean hot water running to the heater core in the summer which I would think would add some heat to the cockpit, and there is no a/c on this car. I went to the store and bought some valves and t's and water pipe and such so I'm going to try to cobble up something and see if it works. I'll post some pic's if I get it to work. Sorry for groveling for some replys too, I guess I just thought my thread made it to the second page awful quick and somebody that had done the repair might have missed it. Race on!
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
CFI's repair is halfassed (and hypocritical too), but I don't blame him, as that heater control valve, at least for 85, is discontinued and the remaining n.o.s. ones are priced insanely high. You'd be better off making one fit from another application.
While we're on the subject, what does the vacuum hookup do? Does that open the valve more when the engine is at idle (and the water pump is turning slower) in attempt to maintain steady flow through the core?
I had the same problem with the leaky valve on my 85. With the valve on the car, I cut it out of the pipe with a dremel tool, and replaced it with longer hoses. I capped off the vacuum line, and hid it in the harness. It looks neater than original, and I noticed no change in interior temp at all. And its very hot here in the summer.
Actually, it wasn't my repair. My car was set up that way when I bought it in 1986. They must have been troublesome from the beginning. I never missed it. It was years until I noticed it in my parts book, and then I realized I had something missing.
The vacuum hose is to open the valve to allow hot water to circulate into the heater core. It is activated by the heater/AC controls on the dash.
I never said that I didn't have a heater. I didn't "then you put a comma in". I did not write what you think you read. Do you see where that post was ever edited? How could I add a comma without editing the post? Nice try, though.
Mine has been eliminated on my car. I haven't had a heater, water, control valve for over 18 years. No problems.
RACE ON!!!
My gosh, I'm seeing a comma after the word "heater" in your post. That makes it read like you don't have a heater. But I guess I should have figured something was amiss since you also put a comma after the word "water" and I guess you probably have water. All of the parts descriptions I've found for the valve list it as a "heater control valve." No mention of the word water in the description. Okay, done with that topic. Don't get so defensive because somebody didn't understand what you wrote.
Also, the vacuum doesn't open the valve. It closes it to stop water from entering the heater core. That way the default if there is a vacuum problem would be to have heat. If you always have hot water in the heater core and you turn the vent on doesn't that run fresh air through the heater core and into the cockpit? Or is there some sort of trap door involved?
The words heater and water have commas as should any multiple adjectives before their subject noun.
If there were an "and" it would THEN say there were no heater.
See post #8 for the description in the GM parts book. I even capitalized and italicized it for you.
You may be right about that. I don't have a valve to check. My FSM merely says "The water valve is vacuum operated..." (there's that "W" word again. That seems odd, however, because then a closed valve would be opened every time the engine was shut off.
The same temperature control that works for the heater, defroster, and A/C functions for the vent, also. As with later year cars with out the water valve, the coolant heat is kept from the passenger cabin.
Jim, not a big problem. We did a cool plumbing thing on it and it seems to work good. It doesn't look that good though, so I'm not probably going to post any pictures. We were over watching the Laguna Seca Speed World Challenge with John Boos today and we showed him the car and he scratched his head. I convinced him that I plumbed it properly and he thought it looked pretty cool then.
And, this thread has taken an ugly turn since somebody wants to argue English and semantics.
