l-98 performance questions
Old Oct 25, 2006 | 07:31 PM
sgtskid's Avatar
sgtskid
Default l-98 performance questions
i have a 1990 l-98 with 66k on it and was wanting to do some mods to it, right now i have a chip, wires, plugs, exhaust, and k&n on it but i was wanting to budget about 3-4k on engine mods. i was wanting some input on stuff to do. I am big on keeping the original block if possible, i was thinking about heads, headers, port & polish the intake? i dont know also i was wondering if anyone has the eradispeed brake kit from mid america or corvette central and the suspension kit from R&D ...i would like to add both of those as well to help it handle. but any input or ideas are welcome
Old Oct 25, 2006 | 07:36 PM
serge's Avatar
serge
From: Olympia Washington 91 Z07 Coupe, 6spd, Borla Exhaust, Perf. Ignition, K&N Filter
i was looking into buying a chip, what kind did u get and what do u think of it?
To help you out, my buddy did a port matching on his car and helped out nicely, also balancing the rotating assembly is always good, but wont give u any increase in performance numbers
Old Oct 25, 2006 | 07:38 PM
zo1boy's Avatar
zo1boy
Welcome to the Dark side....
http://temp.corvetteforum.net/c4/vader86/
Old Oct 25, 2006 | 07:47 PM
sgtskid's Avatar
sgtskid
I have a hypertech chip, i think its called the thermomaster from mid america, but you have to install a colder thermostat as well...i could tell some difference whether its in my head or not i like it and i like to think it helped. but its been so long since ive installed it i dont remember the before to well.
Old Oct 25, 2006 | 08:00 PM
cplonner's Avatar
cplonner
Pcmsforless.com go there much much better. Do all your mods and then get the chip. Pcmsforless is custom to exactly what your car will have after you mod it and it will still be cheaper.
Old Oct 26, 2006 | 09:31 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
I can't tell you how happy I am with mine.
Good advice though. Put your stock chip back in. mod your car, then send Alvin at PCMFORLESS an order and list EVERYTHING you did to the car performance wise. He can program it for all your mods to get the most out of it.
the hypertech is ok if you have a 160* thermostat and its a stock car. but once you start modding, it will only hinder performance.
I had one and sold it. Once I put the stock chip back in, i was like WOAH this is a completely different car! then once I got my pcmforless chip in, it was like an ever better completely different car!
Good stuff, just make sure you do it last so you can avoid having to reburn a new chip multiple times due to excessive modding that needs new programming
Old Oct 26, 2006 | 10:33 AM
vader86's Avatar
vader86
It depends on how fast you want to go, and how much you can do yourself. Buying parts used is the way to go if possible. You may find a deal on a SuperRam if youre patient.
I wouldnt bother with the Baer kit there, its not really anything better than the C5 package, just that the Eradispeed rotors are pretty. You can get the C5 parts necessary and paint some Durastop rotor centers and it'll be fine.
RD parts are always good, as are VetteBrakes' suspension parts.
Old Oct 31, 2006 | 08:07 PM
sgtskid's Avatar
sgtskid
i dont want to go real fast as there are not really any places to go real fast on the street. i would just like to get some extra power just something to be a little above the rest of the vettes at the show. i was thinking just like heads, headers, stuff like that. I work at a performance shop so all the install i can do myself but the machine work i will have to send out.
Old Oct 31, 2006 | 09:45 PM
Vic'89's Avatar
Vic'89
Stock chips work fine for a bolt-on setup.
Do not waste money on these so called aftermarket chips, unless they are a custom tune.
Vic
Old Oct 31, 2006 | 09:55 PM
sgtskid's Avatar
sgtskid
i appreciate all the advice but i keep getting responses about chips...i am not asking about chips i am asking about heads, headers, cam, etc any advice in this area?
Old Oct 31, 2006 | 10:21 PM
Trog's Avatar
Trog
w/ welcome to the dark side. I didn't do any real mods the first 8 years I owned my 90... the last 6 have been another story.
I started down the road of simple bolt ons, headers, catback, 1.6 rockers, AFPR, K&N filter & open lid, etc... then a coolant leak out the back of #7 head gasket was an excuse for new rings, timing set & the TPIS Big Mouth intake & runners, minor port/polish & port match, new valve springs, guide plates, Corteco thin head gaskets & a chip. That was all fine & good until a fellow forum member dumped a brand new D-1 procharger kit that had sat for 3 years in his garage... now it's gasous intercooling & all the power I could ever need.
Did I mention the DRM extra grip setup w/ coilovers, a grafted stock X-brace & now a customized camber brace to clear the supercharger. Have I stopped yet... no... see what happens!! Don't do it man, the first hit seems so innocent and easy now I'm hooked.
Old Oct 31, 2006 | 10:54 PM
sgtskid's Avatar
sgtskid
thanks for all the advice guys
Old Nov 1, 2006 | 08:58 AM
GIJoe's Avatar
GIJoe
$3-4K can get you quite a bit in mods!
question though: if you don't want to go really fast, but 'want to be faster than the other corvettes at the show"... what does that mean? why bother modding your car out if you dont have anywhere to drive fast, dont care to drive that much faster, but just want to have more mods than the guy sitting next to you at a car show, but not really even use the extra power?
Not doggin ya, to each his own, but there seems to be a quite a few other things you could do with that money if you don't really even plan to use it, like visuals or something (wheels, stereo, interior, paint, etc?)
I could build a badazz home theater setup for that much money if i wan't planning to use the extra power in the car
Old Nov 1, 2006 | 09:54 AM
Red Tornado's Avatar
Red Tornado
Originally Posted by sgtskid
.... i would just like to get some extra power just something to be a little above the rest of the vettes at the show.
like GIJoe's post above, then you'd be better served settling for stock performance. keep your money.
doing anything because of some silly car show will prove useless and meaningless.
Old Nov 1, 2006 | 10:21 AM
neat's Avatar
neat
Nitrous. Spray that sucker like a roach!
Heads/cam/intake... There's a million ways to build an SBC combo, that's why your not really getting responses on that.
If all your looking for is the 'wow' factor, nitrous is tough to beat. A big bottle in the back and a big purge can drop a lot of jaws. Other than something that is crazy expensive like a turbo or S/C set-up, I think nitrous will draw the most attention.
If you are dead set on doing heads/cam/intake, I like this combo:
Mini-ram intake
CC306 cam
Canton heads, or some other 195-200 CC head
A nice valve train so you can spin it to 6500 reliably
Hooker long tubes, or some other long tube header
That should net you ~350 RWHP, possible more. There's a lot more to any combo, but those are the basics.
Good luck, let us know what you decide to do!
Old Nov 1, 2006 | 10:24 AM
Red Tornado
neat, this is going to be the 1rst time i solidly agree on the nitrous option. the OP sounds like the 100% perfect candidate for this.
Old Nov 1, 2006 | 10:31 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
The L98 was notorious for poor breathing
Youve already donr the downstream side
I bet a better intake would wake that thing up
Old Nov 1, 2006 | 10:53 AM
Bad Karma's Avatar
Bad Karma
I like power anytime I want it, not at the push of a buttom when the bottle is full, but if you are going more for the show, then slap a nitrous kit in, the bottle does look mean, and then you have the option for the occassional spray should you decide you actually want to get her going.
I would definately say go with a nie set of Ceramic coated headers/Y-Pipe, and a high flow to finish off your exhaust. If you are going for more show, dress up the engine bay. Get a nice set of Valve covers, and while they are off, put in a set of rockers :-) Just work on the little details they will make the engine more impressive when you pop the hood.
Old Nov 3, 2006 | 10:30 AM
sgtskid's Avatar
sgtskid
I didnt mean i dont want to go fast, I was more less saying that I don't want (well want is one thing but practical is another) a car with an insane amount of horsepower. I drive a local road called "The Dragon" or hwy 129 that road is not really for speed as much as it is handling, but a little extra wouldnt hurt. As far as going for looks I like the look of my car and about the only thing I plan on changing are the wheels somewhere down the road. I like the clean lines of it without body kits or spoilers. Because to me that starts getting into (this one might cause a stir) the ricer catagory. But like i said earlier thanks for all the advice everyone!!
To l-98 performance questions
