I have a 91 with flowmasters on it everything else is stock. I'm thinking of modding it along the lines of a Miniram, long tube headers, losing the cats, and maybe a mild cam. Is this going to make a major difference in performance? I don't care about 1/4 mile time or hp to much. I just want a throw you back in the seat street car. Thanks.
*edit* Oh yeah, I'm only looking to spend maybe 2k-3K.
The miniram will change the character of the engine. It will turn it into a 6000 rpm screamer. Cam will compliment. The mods you mention will make the car feel and run completely different.
Alright thanks. I was just wanting to double check before putting money into it, and then being disapointed with the result.
I did not mean to imply that the parts you are choosing will make you happy. I do not know your goals. Miniram combos like loose torque converters and steeper gears to take advantage of the higher power band.
I personally perfer a torque combination rather than a high horsepower combo. That is a matter of personal opinion though.
I was just looking to make sure those parts would make a difference. I use this car as my DD so i'm not really looking to make it a ungodly fast car. My goal is to make it into a torquer throw you back in your seat ride.
Consider the possibility of a Superram manifold or a modified tpi system as well. The mini ram is not known as the torque monster manifold. High rpm's is where it shines.
the mini ram makes it more like the LT1, gotta love those high revs.
the mini ram will significanly change your flow profile on the intake side if you are chooseing a cam and you have no intention of doing anything exotic like forced air or stroking the have contact compcams for a custom cam setup the cost will be worth it dont take the word of some half a$$ poster on a forum or web site that this specific cam will work best with your setup. stock cams are not bad but they where designed for efficancy with the head and intake not power.
You should read my website, click my name. These decisions with heads/cam need to be carefully considered, as then you will have to modify other things to go with this intake change, like your rear gearing. Basically your mods will then follow what LT1 guys do to their cars.
Yes the heads NEED to be ported to optimize this combination, actually even then they still would be on the small side for what the miniram can do in potential. Camshaft selection will range from something as small as the ZZ9 (also from TPiS) to hotcam/cc305 for something that is potent but still very driveable.
This would probably be the issue unless you find the parts used. Intake new complete is around 1200. new heads around 1400. (porting existing is a bit cheaper) then include cam, rockers pushrods, timing chain, gaskets lifters etc. you will be into to it for more like 4k+.
I wouldn't let the loss of low end torque deter you. LT1's make more than enough low end power to have fun with, and the upper end is great. Low end torque kinda seems to be something the L98 guys bragg about, and in my opinion they make too much out of it.
Maybe find an LT1 powered car at a dealership and go for a test drive. A Camaro, Firebird, or C4; it shouldn't matter. Any of those would give you an idea of the power band you'll have with the mini-ram. With the right heads and cam combo, ~350+ RWHP isn't out of the question. I am a few paychecks away from pulling the trigger on this combo:
i partly agree with neat, if your budget is 2 to 3k, invest in a good set of heads not from ebay, and use a converted lt1 intake. for 1k you have a lot of choices for good name brand heads like edelbrock or trickflow, a converted lt1 intake with fuel rails is 400 bucks, compare that to the 1200 you are going to spend on a miniram.
i would have gone this route myself, but i already had the miniram. If i could do it again, i would have spent 2k on a set a bad ***, afr's, and 400 on a converterd lt1 intake. good luck.
How hard is the lt1 intake to install? I know that the mini ram gives you more power in the upper rpms, but where does the super ram start to choke up (what rpm)
