Building a "compromised" car
So what type of things should I consider not doing while building it? IE what modifications that are done to the car to make it extremely competitive in one venue make it unuseable in another? Example as a real basic, obviously I am not going to remove the sway bar to make it a marginally better drag racer because that would make it an absolutely horrible autocrosser.
Suggestions or things I should consider?
Roy
several different venues. I would like to be able to take it to the
dragstrip, the local autocross, and to the top speed runs in N.C.
been to focus on durability modifications for these activities and let
the requirements for the other events take a back seat. I am
thinking about ensuring adequate lubrication & cooling (fluids & brakes).
Safety gear appropriate to the usage and before performance gear.
The mods will come as you see the need for them.
I.e.: You're a smart boy, you'll figure it out at the appropriate times.
Larry
code5coupe
Roll bar for safety works in any venue
You can remove the front sway bar easily for drags. Change out shocks and you are ready to go.
Since you plan on rolling it fast down the highway in a sanctioned ORR event, you MIGHT need to worry about changing out the rear for better final drive ratios. Depends on what you want to run at the 1/4 and Autocrosses. The 4:10/4:11 ratios are good for acceleration, but the pits when you want to run top-end. I've collected an extra bat-wing with D44 so I can swap out the entire rear without cracking the case.
Also, You might want to check what the ratios are on the steering box. Since mine is a Z07, they came with a quick-ratio steering box beacuse the car was intended to be autocrossed. For ORR runs, the steering is too twitchy, so I'll need to swap out the box to slow it down a bit.
The normal stuff other than that...oil coolers (trans and engine), power steering cooler (autoX is tough on the steering system), good AL radiator, and J55 brakes (minimum for autocross and high-speed runs).
Also can't recommend enough to get a Canton Road Race pan...good insurance for sure. An AccuSump in addition to the Canton pan is even better
