Need Help with Clutch Choice
Old Sep 19, 2001 | 12:13 AM
Life's Sweet's Avatar
Life's Sweet
Default Need Help with Clutch Choice
I have recently purchase a 96 LT4 that was modified to a 383 stroker. The hp is rated at 430 and the torque at 435. The original clutch was a Centerforce Dual Friction and had been replaced prior to my purchase. A stock GM clutch was installed as its replacement. The flywheel is a single mass. From what I have read, the stock clutch is not a good match for this kind of power. I plan to use the car for street and autocross. I would appreciate any recommendations and experience with various clutches for this setup. I'm leaning toward another Centerforce DF or the McLeod Twin.
Old Sep 19, 2001 | 04:03 AM
Janaelen's Avatar
Janaelen
Default Re: Need Help with Clutch Choice (Life's Sweet)
I currently have the Centerforce Dual Friction. I paid $579.00 at the time and it was quite a bit cheaper than the Mcleod(if I remember correctly).
I've had a few times it slipped on me (4k launch and went through 3 gears before I realized the smell of slipping clutch). As far as a rolling start, as long as I don't try to rev the motor too high with too much boost, I'm o.k.
Old Sep 19, 2001 | 01:55 PM
NeedSpeed's Avatar
NeedSpeed
I'm talking with a guy form Star Clutch right now. I need one too, but I don't have that kind of power.
Their stage II is $449 and good for 525HP.
They got good press, and I'm in the process of choosing.
Old Sep 19, 2001 | 02:00 PM
Chris@SD's Avatar
Chris@SD
We have been sending the Stage II STAR/SPEC clutches out on a regular basis and have yet to have a problem. They have all held up very well.
We would be more than happy to help you out with these if you would like.
Thanks,
Old Sep 19, 2001 | 02:08 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
Default Re: Need Help with Clutch Choice (NeedSpeed)
I installed a Star stage II in mine earlier this year. So far no problems. Feels like stock, hasn't slipped and proved that it was stronger than my BF u-joints on a 2500RPM launch. Nothing but good things to say about Star so far.
Old Sep 26, 2001 | 12:06 AM
Life's Sweet
Default Re: Need Help with Clutch Choice (Thumper)
Thanks for all your replies. I spoke with Callaway concerning my clutch problem and they suggested that I should stay with the Centerforce dual friction. The clutch was part of the super natural conversion and was a factor in the subsequent performance documentation.
Old Sep 26, 2001 | 10:13 AM
Hammer's Avatar
Hammer
Does anyone know if you can "ride" the star clutch out of the hole, or is a on/off type?
Jim
Old Sep 27, 2001 | 10:21 AM
Hammer's Avatar
Hammer
Default Re: Need Help with Clutch Choice (Hammer)
ttt
To Need Help with Clutch Choice
