Copper header gaskets?
Old Oct 29, 2006 | 08:42 AM
Strick's Avatar
Strick
I run shorties and OEM cats to a B&B exhaust. I have 15K on them and no leaks at all. I used copper header gaskets AND with the use of allen socket head header bolts (which allows easy torque readings on ALL the header bolts) no problems to date. I agree with the idea that there might be too much weight put on the headers if the exhaust is not properly supported, but a quality header will have a flange that should be able to provide support without leaks.
