85 cooling ?
Old Oct 29, 2006 | 12:12 AM
Steeler1's Avatar
Steeler1
Default 85 cooling ?
Thermostat opens at 160 fan on at 180... L98
If i put higher thermostat. How do i raise the fan on temp?
Old Oct 29, 2006 | 01:03 AM
jfb's Avatar
jfb
Except in the winter, your fan is going to be on all the time!!! Your radiator cannot get rid of heat fast enough to maintain coolant temp below 180.
The only way to turn on the main fan at 180, is to install a chip programmed differently than stock. The stock chip turns the main fan on at 228F and off at 210F.
Old Oct 29, 2006 | 01:14 AM
vader86's Avatar
vader86
The fan setting is controlled in the ECM, it can only be changed there in the chip. 180 is too low, that fan will run all the time. It does not know or care what your thermostat is doing.
Unless you have wired in a switch to make it come on sooner and bypassed the ECM's control, thats the only way to change it.
160 is a choice I make based on climate and driving conditions, my site has my opinion on that.
Old Oct 29, 2006 | 01:16 AM
Steeler1's Avatar
Steeler1
Then I need a chip to change the temp that the fan comes on at?
Old Oct 29, 2006 | 01:22 AM
Steeler1's Avatar
Steeler1
Ok i see ... the settings now are 160 fot the thermostat and 180 for fan
I want to put them back to stock.. I thought the temp sensor controlled when the fan came on.
Old Oct 29, 2006 | 01:34 AM
vader86's Avatar
vader86
temp sensor only tells the computer what the temp is, it does not directly control the fan unless someone has wired a switch off of it to do so
Only way to change the fan setting is to reprogram your chip. If it is coming on at 180, then it has been reprogrammed before or someone changed it before.
Old Oct 29, 2006 | 07:31 AM
RRT vette's Avatar
RRT vette
I agree with the above. Your dash readout comes from (in 85) a coolant temp sender in the drivers side head betwen #1 and #3 spark plugs. In the later year L98 the sender is in the passenger side head between #6 and #8 spark plugs.
The main fan (between radiator and engine) is controled by the ECM which is given coolant temperature information from a coolant temperature sensor in the front of the intake manifold (resistance variable). You can either get a chip tuned to change the fan "on" temp or wire a switch in. On a scan tool you could notice a difference in temp readout on the guage and on the tool if one or the other (sensor/sender) is sending poor signal.
The t-stat controls the warm up time and minimal operating temp of the engine, only.
You also have should have a auxillary fan between the front bumper and radiator only seen from under the bumper. It is controled by a switch (in 85) in the passenger side head between #6 and #8 spark plugs. In later year L98 the aux fan switch is in the drivers side head betwen #1 and #3 spark plugs. The aux fan comes on around 235* stock. Your aux fan probably has spider webs on it.
Old Oct 29, 2006 | 11:16 AM
CFI-EFI's Avatar
CFI-EFI
Maybe. First you have to determine how the fan, on temp, was altered. Certainly the cleanest way is to swap chips, but there are many ways to accomplish this. Another way, is to install a lower temp aux fan switch and wire the two fans together. RRT vette does a good job of describing the workings of the system, but he left out an important piece of information. The auxiliary fan (RPO# B4P) was not installed on all cars. The 1985 was unique in that cars without the aux fan still got the fan switch and it was wired to back up the ECT sensor/ECM operation of the main (the only in that case) fan. One could install a lower temp fan switch on such a car and the lower temp of the thermal switch would turn the fan on before the ECM would. In short, in order to undo what has been done, you have to figure out what was done. If the fan(s) were rewired, changing chips won't help.
RACE ON!!!
Old Oct 29, 2006 | 11:37 AM
Steel Breeze's Avatar
Steel Breeze
I have been trying to rationalize some people hooking there main fan on relay to the aux. fan switch in the head. Even if they change the aux. fan switch to a lower temp. How does the air conditioning turn the fan on/off then??? Wish I had a vol. 2 FSM wiring manual...
Old Oct 30, 2006 | 05:06 PM
Steeler1's Avatar
Steeler1
I don,t think the main fan was wired into the aux. fan switch.
What I found was the wire from the harness to the main fan relay has a 30 amp fuse installed between the harness and the switch.... but with no fuse and one end taped up.
I found a hypertech sticker on the air dam.. so i'm thinking there is some kinda chip and that's why the lower t stat.
Any way to determine what the chip is without taking it out?
Car runs good kick into it at about 65 and i'm doing 100 in a heart beat
Old Oct 30, 2006 | 06:02 PM
RRT vette's Avatar
RRT vette
The only way to check the chip is to remove the ECM and remove the cover to get access to the chip. It should say Hypertech on it. There is no way to know what is programmed into it from visually looking.
Old Oct 30, 2006 | 06:17 PM
vader86's Avatar
vader86
No the chip must be removed from the computer and plugged into a chip reader and a laptop or PC to determine what its' settings are.
Old Nov 4, 2006 | 01:09 AM
sonny746's Avatar
sonny746
My 86 is stock and the fan usually turns on at 228 and off at 210. Lately,
my fan is acting up. Sometimes it won't even turn on until 235. Could this be a fan switch problem?
To 85 cooling ?
