My coupe won't idle...
Old Oct 29, 2006 | 11:56 AM
mikey whipreck's Avatar
mikey whipreck
Default My coupe won't idle...
and the EGR valve won't hold vacuum.
Are they related?
Thoughts? Opinions? Rants?
Stats: 1985 Stock L98, idle recently got very bad, very fast. Will run and drive, and idle only if I hold the gas- otherwise it will stall out. Also hesitates. Doesn't miss, TPS is .51, FP is 38psi on priming and holds for an hour. Timing at 6*. Battery shows 12V charge, and Alt runs at 14.7 on startup. My FSM leads me to the EGR as the culprit, but I wanted to get the Forums' thoughts.
Old Oct 29, 2006 | 12:40 PM
rick lambert's Avatar
rick lambert
Mikey, there should be no EGR in park or neutral. But you should be able to get 10" vacumn, on an 87 the vac. should hold for at least 20 seconds. Have you tried plugging off the vac. line to the EGR and see if things improved?
I don't get this part " also hesitates. Doesn't miss".
Old Oct 29, 2006 | 03:45 PM
IRAraid's Avatar
IRAraid
Default Leaky EGR
An EGR that won't hold vacuum causes two problems. A little leak in the vacuum control line. And an intermittent (sometimes huge) problem in the recirculation line. If the valve sticks open wide enough, the car won't start and will idle roughly at best. Highway driving might not be affected much.
Old Oct 29, 2006 | 09:08 PM
CFI-EFI's Avatar
CFI-EFI
[/QUOTE=mikey whipreck]My coupe won't idle... [/QUOTE]Cut the roof off. Maybe it will idle as a convertible.
The EGR valve is opened by vacuum. The ECM does not supply any vacuum to the EGR valve to open it at idle, as the EGR is to remain closed at idle. Therefore, an EGR valve with a bad diaphragm (it won't open) couldn't be the cause of the bad idle or the hesitation, when it shouldn't be open anyhow. IF the EGR is stuck open, unrelated to whether it holds a vacuum, or not, THAT could be the cause of of the idle and hesitation problems.
RACE ON!!!
Old Oct 30, 2006 | 08:08 AM
mikey whipreck
Old Oct 30, 2006 | 09:22 AM
HeeHaw89's Avatar
HeeHaw89
I recently replaced an EGR that did not hold vacuum. I had no idle or hesitation problems.
Old Oct 30, 2006 | 09:41 AM
RRT vette's Avatar
RRT vette
mikey, I would like to help though I don't think the EGR is the problem. So, basically you have to hold the throttle plates open a little for it to idle correctly?
I'm sure you know these, but I will list anyways. Check /clean the IAC and TB. I'm not certain if the TPS voltage is different but maybe move the voltage up. Have you set the minimal idle yet? The base idle is in the chip. Have you ohmed the CTS in the intake manifold?
Lots of questions, but trying to get a little more info.
Old Oct 30, 2006 | 04:21 PM
mikey whipreck
Sorry, that was two separate thoughts. 1- I meant that the car hesitates if I step on the gas quickly. 2- When driving, the car doesn't miss at all, it just won't idle.
I have to hold the throttle down a little, because, when cold, it will not idle at all. After its warmed up, it will, sometimes,hold an idle, but it will be poor at best.
Cleaned the TB and replaced the IAC a while back. TPS voltage is supposed to be .54v, but it is within spec of my FSM (+/-.075), so I figured that was okay. Reset the IAC per FSM instructions.
I have never ohmed the CTS, I can give that a shot.
I was led to the EGR because a number of engine people I talked to locally said I was perfectly describing an EGR problem, CFI-EFI indicated I may be experiencing the issue and IRAraid described it perfectly.
I should probably start a new thread for this topic, and may do so after I replace the EGR valve (it is bad afterall). My engine feels like its getting too much air, if thats even possible or makes sense.
Thanks for the ideas.
Old Oct 30, 2006 | 04:29 PM
RRT vette's Avatar
RRT vette
If you have supected the EGR valve to be faulty and stuck in the open position...replace it and see if there is any change.
Old Oct 31, 2006 | 03:06 PM
teufelhund's Avatar
teufelhund
I am currently having the same problem. For some reason it won't hold an idle to save it's life and I'm sorry but I was an import guy so I know the ins and outs of a small motor but these v-8's got me stumped. My problem started when I went to get it e-checked and I'm wondering if the guy was messing with the electronics enough to mess this up. He also said my timing was just a little off so I'm wondering if that could have anything to do with it.
Thanks for any help you can give me ahead of time. I'm on leave right now so I won't be able to mess with my car until next monday so I'm hoping to get as much info as possible until I go back to Cali and start working on the new baby.
Peace,
Merritt
Old Nov 24, 2006 | 11:11 PM
mikey whipreck
Thought I'd finish out this old thread.
I finally got around to replacing the EGR valve- Now my '85 will idle again. That was the problem.
Old Nov 25, 2006 | 12:23 PM
rick lambert
Thanks for the follow up mikey it helps us all.
Old Nov 25, 2006 | 12:34 PM
CFI-EFI's Avatar
CFI-EFI
That is great that you've got it idling well, again, but then as I said in post #4, it had to be hanging open. It wasn't because it wouldn't hold a vacuum.
RACE ON!!!
To My coupe won't idle...
