fuel pressure reg ??
Oct 29, 2006 | 02:12 PM
St. Jude Donor '05
If it goes bad will the fuel pressure go up or down?
Running rich and i dont know why.
Oct 29, 2006 | 02:43 PM
Usually down. Pull the vacuum line off the FPR and look inside. There should be no signs of gas.
There are a few things that can make it run rich.
Extra fuel enrichment can only come from a few possible sources:
Quote:
Originally Posted by tequilaboy
1 leaky or shorted injector
2 leaky fuel pressure regulator
3 leaky or shorted CSI
4 Bad coolant temp sensor (rich in open loop)
5 Bad tps (premature PE)
6 Bad MAF or MAF calibration (increased load -> increased fuel)
7 Excessive fuel pressure
8 Excess air in exhaust (causing lean O2 readings in closed loop)
