I have an 87 which was pinging at WOT, so I checked the timing and found that the previous owner has it set to 10 degrees which would probably explain the pinging. My question is this-how do I move the distributor? I took it all apart, when I got to the metal piece that moves the rotor, I found there is really no way to loosen the bolt in the middle. How do I get this thing loose? Thanks alot.
no you dont take it apart. there is a 9/16 bolt underneath the distributor that screws into the intake manifold that holds down the distributor with a clamp. loosen that bolt a little and rotate the whole distributor cap, wires, and all with your hand.
btw, try filling up with 93 octane. it might make the pinging go away. also, your gonna need some special kinda wrench to get to the distributor hold down bolt. its in an akward location. i use a crowsfoot wrench. its a 9/16 wrench that has a hole in it for a 3/8 ratchet. that with a 12 inch extention and a ratchet makes easy work of it. they make special distributor wrenches but i have found the crow's foot works much better.
Also..... there is a single brown wire on the driver's side that you need to disconnect before playing with the timing, and the reconnect after you are done. If I remember right, this is what the ECM uses to adjust the timing electronically.
:cool: No biggie scorp. I was hoping you were on to something b/c I hav'nt tried to advance the timing yet. I'm racking my brain trying to figure out why I cant hit 13's yet.
no the stock programming assumes it is at 6*, so putting it at 8* would give you 2 degrees advance across the curve. Hmmm interesting, I think I'll give it a try, thanks guys!
Thanks for the help. I found the bolt. One problem though. My timing light just fried something. I had it clipped to the battery like its supposed to be, but when I started the engine, the clip popped off and something a little to the left of the battery started smoking. I got the fire extinguisher ready but nothing caught. Now the engine rotates but wont turn over. Any idea what my dumb butt killed? :rolleyes:
