descreened maf
Old Oct 30, 2006 | 07:04 AM
1blkc4's Avatar
1blkc4
Default descreened maf
just bought a 94 noticed the maf screen is missing the car has a k&n lid and filter , should i be worried??
Old Oct 30, 2006 | 08:15 AM
BlackC6LS3's Avatar
BlackC6LS3
I'd say no. The descreened MAF was a popular "performance modification" for the TPI cars. Many people have run them without problems. I doubt itever provided any performance but its like the air foil, we know its worthless but people still buy it.
Old Oct 30, 2006 | 08:37 AM
Casethecorvetteman's Avatar
Casethecorvetteman
No you dont need the screen.
Old Oct 30, 2006 | 08:55 AM
RRT vette's Avatar
RRT vette
The purpose of the screen is to straighten out the airflow throught the MAF, so without it the air flow can be a little turbulent. It also may serve a purpose to block objects in the air flow from touching the hot wires.
You should be fine without it.
Old Oct 30, 2006 | 09:09 AM
Kool88vette's Avatar
Kool88vette
I ran my 88 for 2 years without a MAF screen and noticed no difference.
The K&N is a good filter. Nothing to worry about.
Old Oct 30, 2006 | 09:20 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
the performance gains from the MAF screen removal would only be noticed at higher speeds. Unless it dies on you, it should be fine.
I had mine removed a while back, but the MAF died a year or so later, so I replaced it, I left the screens in. I didn't feel the need to remove them for the risk or some crap flying in past the filter housing and messing up the teeny wire/sensors in there and costing me another $400 to replace it
Old Oct 30, 2006 | 11:59 AM
F1Fan's Avatar
F1Fan
C5 Z06's came without the screen if that tells you anything...
Don't worry about it.
Old Oct 30, 2006 | 07:33 PM
1blkc4's Avatar
1blkc4
hey guys thanks alot
Old Oct 30, 2006 | 07:37 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
I have eight MAF screens in the top of my toolbox. Want some?
Old Oct 30, 2006 | 08:01 PM
Road Agent's Avatar
Road Agent
Another GM screw up, ditch it!
Old Oct 31, 2006 | 12:38 AM
SunCr's Avatar
SunCr
Never seen a documented test to show that it does anything on a stock motor. Most of the Auto Mags now say to leave it to protect the wire from debris. They also say that the MAF either reads the correct amount of air - or it doesn't. Makes sense. Hook up your scanner and see what it says. I'm running my spare, 17 year old screenless MAF (from when the experts were telling you to remove it) because my 2 year old screened MAF suddenly went lean. Runs great again (which is good because I had to ace the biennial smog test today - which it did).
Old Oct 31, 2006 | 03:05 AM
cv67's Avatar
cv67
St. Jude Donor '05
Noticed 0 difference between screened and descreened.
Old Nov 14, 2006 | 02:26 PM
steven mack's Avatar
steven mack
I would be interested in a couple of screens
Old Nov 14, 2006 | 02:35 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Ive never understood the screens in the first place
Does anything get past the filter big enough to need a screen?
To descreened maf
