four post lift install question
Old Oct 30, 2006 | 09:59 PM
jimkari's Avatar
jimkari
Default four post lift install question
I am planning to install a Bend-Pak HD-9 lift in my garage. Based on the desired location, one of the posts will end up about 1 inch from a hairline crack in the floor. As anyone reinforced their concrete floor in order to support a four post lift and if so, how big did you make the piers and did you use rebar?
Thanks,
Jim
Old Oct 30, 2006 | 11:35 PM
tonymax2's Avatar
tonymax2
Are you putting anything other than a 4000# car on this lift? What does the manufacturer say the lift weighs (total). Do you know if there's any reinforcing steel in the existing floor (there should be some, even is it's only the "standard" steel fence).
All concrete cracks. The rebar just keeps the cracked slabs together so the "nooks and crannies" can still support a load. Prestressed steel/concrete beams are a bit different but the fundamentals still apply.
Old Oct 31, 2006 | 07:15 AM
toptechx6's Avatar
toptechx6
Shouldn't be a problem but suppose it depends on the crack. I just installed a 10,000 lb. two post which would have higher load per post and the reqirements were 4 inch concrete. Install instructions suggest pouring a 4' X 4' pad 6" thick if the original concrete is less than 4" thick, no mention of rebar.
Old Oct 31, 2006 | 08:45 AM
JLeatherman's Avatar
JLeatherman
My uncle is installing one right now. He actually cut a square out of the floor and dropped a steel plate in with all-thread rods bolted to it. Then he filled the hole back in level with the rest of the floor and bolted the post to the rods. If you're just lifting your vette you should be fine because it is a light car and it is well balanced front to back. But, if you're ever gonna remove the engine from a truck or do something with a very unbalanced car you might want to do some reinforcement.
Old Nov 1, 2006 | 06:34 PM
jimkari's Avatar
jimkari
Guys thanks for the feedback. The Bend-Pak lift is rated for 9,000. For the most my Corvette will rest on the lift and sometimes my son's 87 Mercedes 300E. However I may want to lift my Expedition (5,500 lbs) once in a while. I spoke with the guys that poured my floor and they said I should be fine as well. My only concern is being right up against the outside garage wall. Here the floor is resting on backfilled soil from when they poured the walls that might not be quite as solid. I may end up cutting out the concrete, going down to the footing and repouring. This is probably overkill, but will give me more piece of mind.
Thanks,
Jim
Old Nov 1, 2006 | 07:03 PM
JLeatherman
It sounds cheesy, but "you can't be too concerned over your own safety." Whatever you end up doing, do it safe and don't hurt yourself or the car.
Old Nov 1, 2006 | 10:30 PM
tonymax2's Avatar
tonymax2
Thanks,
Jim
If you're really concerned about that area, and from my experiences with concrete contractors you may have good reason to be, locate a "concrete leveler" who uses pumped concrete to level existing slabs. It requires drilling holes thru the slab at a few places in the area you want to raise (reinforce) and pumping a cement/sand slurry under it. I supervised raising a 6"x20'x60' slab with a bunch of steel chemical plant equipment on it back in '74 and it was a very slick process. String a line spaced out from the top of the footer or foot wall on the outside (if accessible) and measure along it as they pump to prevent a side "blowout". Measure the elevation of the floor in the area being pumped to gage when it's filled underneath by slight (tenth of an inch) rise. The pumps are usually low pressure, air operated double diaphram types so it's not very equipment intensive and shouldn't be that expensive.
To four post lift install question
