Dart Pro 1 users or spark plug experts inside please
Old Oct 31, 2006 | 03:23 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Dart Pro 1 users or spark plug experts inside please
Which spark plugs are you guys using with your Dart Pro 1 alum heads? The plugs Dart recommends are the Autolite AR3933 but these are not resistor plugs. I know I need a resistor type plug w/ .750 reach, 5/8 hex head, 14mm threads but I don't know the heat range I should use. Oh yeah and I'm looking for a Champion plug because of header clearance. So far I came up with Champion # RC12YC. Am I on the right track?
Old Oct 31, 2006 | 04:17 PM
BTTB's Avatar
BTTB
Default plugs
Was using champion 12yc---switched to nkg r5671a. engine builder recomended this change. The nkg are one range colder.: Ran strong with both sets.
Old Oct 31, 2006 | 05:00 PM
NUckINg FuTS
Thanks. I may go w/ the RC9YC just to be on the safe side.
Old Oct 31, 2006 | 05:08 PM
NUckINg FuTS
Also will I have clearance issues w/ a projected tip plug on a ZZ4 shortblock w/ flat top pistons?
Old Oct 31, 2006 | 05:14 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
ngk fr5
Old Oct 31, 2006 | 05:18 PM
USAsOnlyWay's Avatar
USAsOnlyWay
acc-0416s
Old Nov 1, 2006 | 12:14 PM
89gta383's Avatar
89gta383
autolite 3926 is stock heat range, 3924 is one step colder, there are also 3923 and 3922, but not quite sure if they are 2 steps colder or not.
Old Nov 1, 2006 | 12:53 PM
sami85L98's Avatar
sami85L98
Gone through Acd rapid fire it good but i think way too hot for summer time, NGK 5151 again too hot, finally went with NGK 7373 (FR5) this i found the best plugs so far on mine.
Old Nov 1, 2006 | 02:52 PM
LD85's Avatar
LD85
Originally Posted by USAsOnlyWay
acc-0416s
Accell shorty plug
Product Description
Spark Plug, Shorty, U-Groove, Flat Seat, 14mm Thread, .750 in. Reach, Projected Tip, Resistor, Each --- ** Shorty Spark Plug: Yes ** Resistor: Yes ** Manufacturer Heat Range: S ** Electrode Core Material: Copper ** Electrode Tip Material: Copper ** Insulator Type: Projected ** Spark Plug Thread Size: 14mm ** Spark Plug Reach: 0.750 in. ** Spark Plug Seat Style: Gasket ** Wrench Diameter: 5/8 in. ** Ground Strap Quantity: One ** Quantity: Sold individually.
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 1, 2006 | 06:37 PM
NUckINg FuTS
I hate accel plugs with their screw-on terminals. I just don't trust that concept. Last set I pulled, the terminals were so loose they nearly fell off
Old Nov 2, 2006 | 07:16 AM
LD85's Avatar
LD85
I put the terminal end in my vice, then put a wrench on the hex, and snugged them tight, no issues.
To Dart Pro 1 users or spark plug experts inside please
