Valve spring Question
Old Nov 1, 2006 | 06:42 AM
grizzlyalan's Avatar
grizzlyalan
Default Valve spring Question
I am pieceing together a LT4 up grade for my 95 lt1. I have the lt4 intake, heads and 1.6 rockers When using a Hot cam will I need to change the valve springs or will the stock LT4 springs work with this cam and rocker combo? Thanks
Old Nov 1, 2006 | 11:10 AM
STL94LT1's Avatar
STL94LT1
Yes, the LT4 springs will work. But, while you have things apart you may want to upgrade the springs.
Old Nov 1, 2006 | 11:12 AM
Bad Karma's Avatar
Bad Karma
I'm a big fan of not doing the same work twice. It would suck to tear it all apart just to do it again.
Old Nov 1, 2006 | 07:21 PM
grizzlyalan
Do you have any reccomendations as to what springs to use?
Old Nov 1, 2006 | 07:45 PM
ALLT4's Avatar
ALLT4
Crane Cams 99845-16 is what I used after many discussions with many knowledgeable members here. They have a much better rate and seat pressure than the stock LT4 springs, plus they'll allow for almost .600 lift at stock installed height.
Normally I'd like to go with a damper but it just won't fit the stock locators so don't buy the 99846-16 set thinking you can get a damper, it won't work.
I've been running these for a while now with the Hot Cam and have no trouble, they fit the stock LT4 retainers and locators like glove.
http://cranecams.com/index.php?show=...&lvl=3&prt=122
The other alternative is to use a beehive spring, I'm not a big fan of those so I didn't even research them.
Old Nov 1, 2006 | 09:33 PM
STL94LT1's Avatar
STL94LT1
Old Nov 2, 2006 | 12:47 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I use the Bee Hive springs and love them.I have other racers that use them, with my suggestion.
Not a problem in 4 years.
You will have to use a diff spring remover for the smaller retainers to install.
Old Nov 2, 2006 | 01:26 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm also a fan of the beehives. They're versatile, their small retainers are very light and there should be no clearance issues with any type of rocker arm. Why would anyone use a spring with a capability of .600 lift with the Hotcam? Running excessively more spring pressure than is required wastes HP and causes accelerated wear of the valvetrain.
Old Nov 2, 2006 | 07:17 PM
ALLT4's Avatar
ALLT4
It's called the future, look ahead type thing. Maybe at some point you'll want a bigger cam, then what, buy new springs again?
I doubt you waste any horsepower, if there is a loss it's probably minimal with a full roller valve train. Plus valve float is a non issue.
Old Nov 2, 2006 | 07:21 PM
STL94LT1's Avatar
STL94LT1
I don't know. Why do you? Beehives are good to .600 lift, and your running a Hot Cam.
Old Nov 2, 2006 | 09:04 PM
96GS#007's Avatar
96GS#007
[QUOTE=Corvette KidWhy would anyone use a spring with a capability of .600 lift with the Hotcam? Running excessively more spring pressure than is required wastes HP and causes accelerated wear of the valvetrain.[/QUOTE]
Just because the spring supports greater lift doesn't mean the open or closed pressures are higher. In fact the beehives are typically less than conventional springs.
Old Nov 10, 2006 | 02:24 PM
Akcelr8 N VA's Avatar
Akcelr8 N VA
What's the part number for the Bee Hive springs for the LT4 hot cam setup?
Old Nov 10, 2006 | 05:01 PM
Corvette Kid
The two choices for these in Comp's springs are the 26915 and the 26918. Check their spring chart on their website as to which one will work best for you. It's a font of good info.
To Valve spring Question
