So PeteK, the time has come....
Old Nov 1, 2006 | 02:46 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default So PeteK, the time has come....
Can you give me and all of us contemplating a rebuild and upgrade for the 4L60E, a parts list with your recommendations for replacement parts and needed improvements? Although I haven't dynoed the newest engine yet, I'm expecting close to 500 lbs.-ft. of torque and would like a little cushion beyond that in case I get mod-crazy again. Also, the best places to buy parts as well as any and all info you'd care to impart. Thanks in advance for me and anyone else who may benefit from your wisdom.
Old Nov 1, 2006 | 05:11 PM
jodyeastman's Avatar
jodyeastman
This is a good question. I don't see many things in the FAQ sections regarding beefing up transmissions. I'm OK for now but with a 383 under contemplation, it's something I may need in the future.
Old Nov 1, 2006 | 05:39 PM
Pete K's Avatar
Pete K
I just saw this. I am heading out to work now, but will gather up some info and post it.
Old Nov 2, 2006 | 12:16 AM
Corvette Kid
Thank you sir and no hurry. I'm putting in a good used one in the meantime so I can take my time building it.
Old Nov 2, 2006 | 09:59 AM
rickneworleansla's Avatar
rickneworleansla
What about a 4L80E conversion? Is it doable? How much more abuse could it handle if built stronger?
Old Nov 2, 2006 | 01:19 PM
bacardioil's Avatar
bacardioil
rickreeves 1
the 4l80e is doable. I used one in my 93.
Old Nov 2, 2006 | 07:50 PM
Pete K's Avatar
Pete K
I started buying parts from Brian Carr at Oregon Performace. He is an e-bay seller with a store. His parts are 1st quality and prices are pretty good.
For a 500+ ft pound car, I like to use:
Alto red clutch kit with Kolene steels.
Kevlar band
29 element borg warner sprag
borg warner lo-roller clutch
stock 10 vane pump
stock 4 pinion planetaries
Beast reaction shell
vette servo
transgo shift kit
reverse piston orifice
high rev sping kit with hardened pump rings
white accumulator springs
.471 boost valve
o ring style lo reverse boost valve (sonnax brand)
Transgo seperator plate
Stuff that is not in the rebuid kit, but you will likely need:
Alot of these parts are inexpensive from the gm stealer:
pwm solenoid
lock up solenoid
pump vanes
new front seal retainer
Filter
new accumulator pistons
Bushing kit
Thrust washer and selective washer kit
servo check ball capsule
Old Nov 3, 2006 | 08:07 AM
Pete K's Avatar
Pete K
Please note that the parts I use work well for me and a few close racing buddies. Others may disagree with some of my parts selections. Until we start having failures, I will continue to use what works for me.
I am looking forward to tearing into my buddy Tom's trans this winter. We have a stock 700 with a beast reacttion shell only, behind a 600 ft lb car. He has 3 full seasons of racing on it. I currently works fine, but we are curious to see what is hurting. If I remember, I will post up some pics when it comes apart.
Old Nov 3, 2006 | 09:56 AM
Corvette Kid
Pete, I very much appreciate your taking the time to compile this comprehensive parts list. Hopefully I won't have to send you a big box of parts half way through the build!
Old Nov 3, 2006 | 10:54 AM
Strick's Avatar
Strick
Hey Chris, are you up to this?:
Old Nov 3, 2006 | 10:57 AM
Pete K's Avatar
Pete K
Show Cris a pic of the other 1/2 of the parts
Old Nov 3, 2006 | 12:05 PM
Corvette Kid
It doesn't look any worse than when I have a Cummins engine or something else strewn over two or three work benches at work. I'm curious, did you ever find a place to install those cylinder heads on an automatic trans?
Old Nov 3, 2006 | 01:51 PM
Pete K's Avatar
Pete K
Don't let us scare you.
The trick is subassemblies. Build them one at a time and reassemble. Nuthin to it.
Old Nov 3, 2006 | 02:17 PM
Corvette Kid
Ain't skeered! But that doesn't mean I might not have a zillion more questions before the smoke clears.
Old Nov 4, 2006 | 09:34 AM
Sliding's Avatar
Sliding
Join the club. I've sent so many PM's to Pete in last few days that my PC keyboard will melt and I haven't even started with rebuild.
Old Nov 4, 2006 | 10:15 AM
Corvette Kid
Do you have a manual? I've got a copy of an early GM manual for the 700R I could send you. It's not Corvette specific but a coworker borrowed it when rebuilding the tranny in his '92 pick-up and said it was an asset.
Old Nov 4, 2006 | 11:38 AM
Pete K's Avatar
Pete K
I don't mind a bit. Happy to help
To So PeteK, the time has come....
Old Nov 4, 2006 | 11:44 AM
Sliding's Avatar
Sliding
Thanks Chris. I ordered ATSG manuals and rebuild DVD. From what I've seen here on forum, these manuals should be very helpful.
Thanks again.
Old Nov 4, 2006 | 11:49 AM
KeyWestJack's Avatar
KeyWestJack
Thanks again.
Do they have a web site?
Old Nov 4, 2006 | 01:53 PM
Sliding's Avatar
Sliding
http://www.technicalvideos.com/video...smission.phtml
You can find both manuals and DVD on this page. However, I bought manuals from e-bay.
