Changing Window Motor on a 95'
Old Nov 1, 2006 | 04:03 PM
CAJUN C4's Avatar
CAJUN C4
Default Changing Window Motor on a 95'
We drilled out the 3 rivets that hold the motor on. 2 of them came out very easily but the third we had to drill from the back as it is directly behind the rack gear.Now we can't get the old rivet out because it hits the slide .When we install the new motor do we use only 2 bolts because the 3rd is really un-accessible and no clearance to speak of for the head of the bolt or nut to fit.Hope you understand what I'm asking.
Apprciate it.
Old Nov 1, 2006 | 05:44 PM
IRAraid's Avatar
IRAraid
Default 95 Window motor
Did this job on a '95 Blazer some years ago. My recollection is that raising the window a little (put a piece of 2X4 under to hold it up) made room to extract the 3rd rivet.
Used a carriage bolt so the head was small. Would have liked to use a stainless pan head but couldn't fine it.
Hope this helps.
