Like stated its a 396ci, 11:1 C.R. Lt1.
Six Speed Trans, right now im running 3:73's But most likley will jump to the 4:11's.
As for heads, I running the New Trick Flows with a custom CNC port 'supposed to be lt4 specs even tho they are lt1 casted' so rasied runners etc. They have been benched flowed in the 320's. Full Ti parts, including valves. 1.6 rockers as well.
I will have the new Elderbrock ram style with short runner intake, 'should be here at the end of the month!' port matched to the heads of course.
Keeping in mind it is in a lighter car, i put the motor in my 69 camaro.
I know I know Camaro, but lt1 is an lt1.
With my 355 i was running the Comp 306 cam. From what iv learned and been told its also not a bad choice for my new setup..
You will get allot of responses here as this is a common question.
But my 396 LT1 has comp cams XE 230/236 cam with 114LS and 544 in and 555 ex with 1.6 RRs. Its a little lumpy for an auto, but a Six Speed would handle it very comfotably.
I wish I had gone with the higher lift version, but am satisfied nonetheless, as it makes 425 rwhp and 428 ft/lbs tq
Now I did have the Hot Cam in there for a while and liked it as it was much easier to drive, but I was somewhat criticised by other forums as being too small. Its all personal preference as dirveability is a important factor and many people have different views of what driveable is. I thinkt he older you get, the less camshaft lope yu want, not all people though, just some
I agree with vis but Cam companies know what they're doing too. in most cases they know much more than a builder. I have a VERY VERY similar cam as steve40th. I have a 388 and my car idles so smooth I wish I went a little bigger. my car is a 6 spd. Depending on your head work and combination of intake/exhaust and other bolt ons A lot of power can be had with that cam. Im at 473 rwhp on a Mustang dyno with that same cam. I'm not saying it would make more on a dynojet because who knows what correction factor they are really using.
I would suggest even a little more lift and duration than that since it is a 396. I also suggest staying with the 3.73s. I rev mine to almost 8k, and I;'m soo soo happy I swapped out my 4.09s for them. If I had 4.09s I would have no traction in 1st, 2nd and partway through 3rd. Right now 1st and 2nd are easy to light up. WIth more cubes and a little more torque I think 3.73s would be perfect for you.
The cam that was selected for Beppe's (conv90) 396 is 230 and 236 @.050 with approx .580 lift on both. 112 lobe seperation. I suspect it will make good power.
Yeah im hoping ill nail damn near 500 at the wheels. So seeing the 475's and etc is keeping my hopes up!
Id like a decent lope, it will no longer be my daily driver so that isnt AS important as it used to be. But defently dont want it to die at every full stop..
My 396 LT1 has comp cams 230/236 cam with 114LS and 602 in and 608 ex with 1.6 RRs. Very happy with my idle (900 rpm) and I shift at about 6400 rpm. Further info in signature
Arnold
What kinda power did you lay down? and what range is the power?
Sorry, never had it on a dyno, but it should be in the range of Steve's Vette. I guess about 490-500 engine HP, not enough for our German Autobahns though.
Everything is here, including the custom length pushrods. Mock up has been done and it is disassembled. I have to do final assembly and crating. Should be done within the next week. I am also working on a trans for Beppe's friend Andrea. Because shipping is so expensive, we are going to ship Beppe's motor and trans, along with Andrea's trans as a package of three. That will hopefully save them money.
Is he using the Superram, and if so is it hooged out?
The Brodix heads he settled on have a 200cc intake runner that requires a 1206 gasket. Beppe will have his super ram manifold welded up and ported to match the head. Car should run pretty good.
I am running the 306 with a bit lower static CR on my 383 and think it is a good daily driver with a nice flat TQ curve. Here is the initial dyno run with only 500 miles on the motor and I reay should get it back and tune a little more.
Torque rules on the street, and any stroker with a decent cam is going to give you plenty. I know the 383/396 engines really are allot of fun. My tires hate them though.
what do u mean welded? is this something that needs to be done?
UD Harold,(username at teamchevelle.com) he designs the new Voodoo line of Cams-Good stuff. I dont have his # but you can find him there. Guy really knows his stuff.
Any of the old bats at Crower cams. They are more on the conservative side but have a ton of know how.
Personally I wouldnt listen to a "cam consultant" who is reading you grind #s off a chart, we know who those are. I suspect a 396 SB Vette wont be listed there.
