Money Pit - 91 A/C system
At any rate, if any of you have had to rebuild your A/C system, here is a list of what is available for a 91.
A/C compressor, (Denso) readily available, $300-$500, depending on where you get them, and it should come with a clutch, although, not all do. Typical failure, front seal. Local A/C shop states they are a great compressor, but Denso won't sell the seal to anyone, and it is about a $20 part. I'm still investigating this part.
Evaporator, readily available, $210-$250.
Condenser, readily available, $150-$200.
Accumulator Dryer, readily available, $65-$75.
Hose, A/C main compressor, readily available, although limited supplies. $65-$70.
Hose, A/C accumulator to evaporator, unavailable anywhere.
Line, Evaporator to condenser, aluminum line, high pressure, unavailable anywhere.
My local A/C shop stated that they could make the lines that are unavailable, but they might not look exactly like what you have, although they would function like the factory pieces. So there you have it, hopefully I have saved you guys a few phone calls, God knows I have made enough of them......
thanks for the info,
CJ
There are quite a few differences between years, so I don't make claims for any year other than my 91, which I now know all to intimately. I also have converted this to 134A, as R12 is about $90 a pound.
Need parts? Call Jason at Vette2Vette. Guaranteed used parts and a great guy.
