700R4 Transmission Problem. Ideas?
Old Nov 4, 2006 | 05:55 PM
106mm's Avatar
106mm
Default 700R4 Transmission Problem. Ideas?
My 700R4 only goes into 3rd and reverse, but otherwise it works great. The shifter moves to the position, but the gears don't engage. It takes off in 3rd and never changes. When the shifter goes into 1st or 2nd, nothing happens. Park is normal. It can be driven anywhere with no other problems. Any ideas?
Old Nov 4, 2006 | 06:17 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Although I'm getting ready to rebuild one, I'm no automatic expert. But sit tight. PeteK, our resident A/T guru, will be along at some point and provide guidance.
Old Nov 4, 2006 | 10:08 PM
106mm's Avatar
106mm
Excellent! I'm not much of a transmission guy myself! Thanks!
Old Nov 4, 2006 | 10:22 PM
Pete K's Avatar
Pete K
Off the top of my head, you may have broken the forward sprag. I will have to check the prefernce chart to be sure. I have been hitting the booze tonight, so my hunch may be off a bit
Old Nov 5, 2006 | 02:43 PM
106mm's Avatar
106mm
Anybody? Anybody? Bueller? lol
Old Nov 5, 2006 | 05:18 PM
Pete K's Avatar
Pete K
You likely lost the forward clutch pack.
Old Nov 5, 2006 | 10:03 PM
106mm's Avatar
106mm
Cool, that's what I'll check first. Thanks!
Old Nov 5, 2006 | 10:14 PM
Pete K's Avatar
Pete K
Usually, once you pull the pump and go inside, the problem is pretty easy to find. Post the results.
Old Nov 6, 2006 | 09:45 AM
106mm's Avatar
106mm
I will. Thanks!
To 700R4 Transmission Problem. Ideas?
