'88 inner tie rod ends
Old Nov 6, 2006 | 03:42 PM
FostersPerformance's Avatar
FostersPerformance
Default '88 inner tie rod ends
I have the steering gear out, took off the outer tie rods ends, got the boots off, and now im not sure. Last time i changed inner tie rods ends, they just unscrewed from the piston. But on this it has a plastic cover-which i can move outta the way to expose a wrench flat. But now the sleeve covers the wrench flat on the piston. it also looks like once its installed, it gets 'pinched' so it cant loosen. If i had the new ones in front of me, id be able to figure it out, but i dont.
Can anyone share some info on removing the inner tie rod ends???? Thanks all!!!!
