86 Brake Question
Old Nov 6, 2006 | 05:43 PM
geezel's Avatar
geezel
Default 86 Brake Question
I've got an 86L 4+3. I assume I do not have anti-lock brakes, correct? I do not have a RPO #JL9 (Brakes, Anti-lock Front and Rear Disc) listed under the console cover.
Old Nov 6, 2006 | 07:13 PM
CG77VETTE's Avatar
CG77VETTE
1986 marked the model year that Corvette introduced front and rear anti-lock disc brakes and I believe they were standard equipment on all models. On the sticker of my '86, anti-lock brakes are listed with all the other standard features and don't have an RPO code.
Old Nov 6, 2006 | 07:46 PM
geezel's Avatar
geezel
The reason I ask, I need to know if I ordered the correct DRM bias spring for my C4-C5 brake upgrade. They listed a spring for 84-86 (non-ABS) and one for 87> (with ABS).
Old Nov 6, 2006 | 08:03 PM
Benny42's Avatar
Benny42
My '86 does not have the option code, but it does have abs. Does your car go "grrrrrr" at 4 mph backing out of the driveway? If it does, you have abs. benny
Old Nov 6, 2006 | 09:36 PM
geezel's Avatar
geezel
It makes the noise allright. I've ordered the bias spring for an ABS car and should be OK.
Old Nov 7, 2006 | 12:09 AM
CG77VETTE's Avatar
CG77VETTE
You can also be sure you have ABS if you have a cable attached to the inner front knuckle behind the wheel bearing which utilizes the gear teeth on the bearing as a speed sensor. See the yellow circle in the picture.
Old Nov 7, 2006 | 06:24 AM
rons85's Avatar
rons85
OK - I'll point out the obvious... The ABS unit lives in the storage area behind the drivers side seat. It's pretty obvious if it's present or not
To 86 Brake Question
