help
Old Nov 6, 2006 | 08:17 PM
byedan's Avatar
byedan
Default help
on my 94 vette sometimes it will want to die if sitting at a light or a stop sign it starts running very rough and acts like it is not getting fire, also the voltage gauge drops but this may be due to the rpms dropping to like 500 rpm. once i get moving again it clears up and runs fine and i can not duplicate the problem it is like the ghost in the machine also it has 83 thousand miles on it and it is a automatic, any ideas would be of great help. thanks
Old Nov 7, 2006 | 09:18 AM
byedan's Avatar
byedan
also no check engine light i am going to try a fuel filter first and then go from there it could be the fuel pump as i have not tested the fuel pressure at the schradder valve.
Old Nov 7, 2006 | 09:27 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
My 92 was doing that and eventually died on the way home one day. A friend of mine suggested replacing the coil, once I changed it she started right up.
Use the FSM and try to track down the problem before throwing hundreds of dollars at it.
Old Nov 7, 2006 | 01:48 PM
byedan's Avatar
byedan
could be the coil i will check that out
Old Nov 7, 2006 | 07:25 PM
byedan's Avatar
byedan
i do not have a fsm but man do i need to get one
Old Nov 7, 2006 | 07:59 PM
KeyWestJack's Avatar
KeyWestJack
Did you check your fuel pressure? Maybe you want to check your idle air control.
Old Nov 8, 2006 | 01:31 PM
byedan's Avatar
byedan
i was also thinking of the idle air control it is hard to say at this point but a coil is cheap and the car has 80 thousand miles on it will not hurt it to have it replaced as well as a opti and water pump and a good tune up
Old Nov 8, 2006 | 01:41 PM
Bad Karma's Avatar
Bad Karma
Don't overlook the simple, could be plugs/wires.
Old Nov 8, 2006 | 07:25 PM
byedan's Avatar
byedan
it is time for plugs and wire i have been putting off because i want to a water pump and opti at the same time which brings me to doing a cam and getting the heads done while it is torn apart
To help
