1988 corvette convertion
Old Nov 7, 2006 | 06:19 PM
blaze2tires's Avatar
blaze2tires
2nd Gear
Default 1988 corvette convertion
Will the intake off my stock l98 fit on a old 67 327sbc
Old Nov 7, 2006 | 07:25 PM
CFI-EFI's Avatar
CFI-EFI
Yes.
RACE ON!!!
Old Nov 7, 2006 | 07:29 PM
89onlyZ51's Avatar
89onlyZ51
You'll have to elongate the two center bolt holes on each side of the base. I believe the angle changed when they went to aluminum heads in 86/87.
Old Nov 7, 2006 | 07:59 PM
CFI-EFI's Avatar
CFI-EFI
WRONG!!!
In 1986 the center bolt holes changed angles in the cast iron heads used in the F body L98 engines. The Corvette aluminum heads along with ALL Gen I and Gen II Corvette intake manifolds retro fit back to the original, 1955, 265, as far as bolt pattern is concerned.
RACE ON!!!
Old Nov 7, 2006 | 08:50 PM
lefoy84's Avatar
lefoy84
Originally Posted by CFI-EFI
WRONG!!!
RACE ON!!!
He is right. Abrupt but right.
Old Nov 8, 2006 | 08:54 PM
blaze2tires
2nd Gear
Thanks alot for the info. The l98 is shot and I happen to have a 327 setting around thats fresh.
Old Nov 9, 2006 | 11:49 AM
CFI-EFI's Avatar
CFI-EFI
As long as it is a Corvette L98, (as in the title to your post), and has aluminum heads, (like all 1988 Corvettes), you'll be fine.
I'm sorry if some think I was abrupt, but what was abrupt, was 89onlyZ51 jumping in, after the correct answer had been given, with false, erroneous, incorrect, misleading, and wrong, information.
RACE ON!!!
Old Nov 10, 2006 | 09:33 AM
todd_vette87
Guest
Posts: n/a
CFI-EFI,
I have sveral intake manifolds, about 8 plenums, at least 6 pairs of runners and 4or5 fuel rail sets. How can i id each of them as to what they are from (camaro or Corvette) and the years they will work on? The fuel rails are easy to tel the make but i have forgotten over the years on the rest. It is time to start selling off excess and i don't want to screw any-body up getting the wrong year/make.
To 1988 corvette convertion
