electrical problems
Old Sep 21, 2001 | 07:10 AM
tomliz's Avatar
tomliz
2nd Gear
Default electrical problems
Hello everyone,
I have just purchased a 1988 . After about 2 days of sitting the battery goes dead. My local mechanic says the digital dash is drawing. Pulling the fuse does not stop the draw. I tried the radio, heater fuse(5A) and that solves it, but everything seems to be functioning properly. Anyone have any experiences with this. Any help would be appreciated, I Hate electrical!!!
Old Sep 21, 2001 | 10:59 AM
GRX's Avatar
GRX
Default Re: electrical problems (tomliz)
First of all, how old is the battery?
Old Sep 21, 2001 | 12:59 PM
jfb's Avatar
jfb
Now find out what is wrong with the radio and you have it fixed. Why do you hate electrical problems, you found it right away.
Old Sep 21, 2001 | 09:32 PM
tomliz's Avatar
tomliz
2nd Gear
Default Re: electrical problems (jfb)
Battery is new, alternator checks fine. Unplug radio still has problem.
Old Sep 21, 2001 | 09:42 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Sounds like it is then in the heater circuit!
Not sure what else is in this circuit. When you say alternator checks fine, how was it checked?
I am electronically impaired/disadvantaged so be carefull how you interpret what I say
But I had a situation where my alternator was slowly leaking to ground and killing the battery
Hopefully someone more knowledegable than I will chime in here
:seeya
Old Sep 21, 2001 | 09:45 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
It sounds like you have a ground in one of the circuits and it is drawing the battery down. Have you checked to make sure the hood lights are out? One thing you can do to find a ground is the "phantom drain test". Unhook one of the battery connections and attach a test light between the cable and the post. Start pulling the fuses one at a time until the light goes out. Once the light goes out leave that fuse out and start putting the fuses back in and see if any other fuses makes the light come back on. Remember some items draw power all the time like the raidio for the clock. If the circuit that you pulled the fuse for shouldn't be on then this is the circuit that has a ground or short and you would need to test it or have an electrical shop test it out.
To electrical problems
