A/C PROBLEM
Old Sep 21, 2001 | 07:43 AM
steve1ph's Avatar
steve1ph
Default A/C PROBLEM
You know its already getting cool and i wasnt in no hurry to fix this problem but regardless it still gets hot in side the car, so the way i see it im proble going to need my a/c to work year round. The problem is the other day after i had a wire burn through on the altenator (main hot wire), now my a/c cuts on and off (clutch), plus only the feet vents are blowing. It was working fine the day befor the alt event. Any suggestions. the car is a 90` L98, computer a/c.
Old Sep 21, 2001 | 10:26 AM
nobodyunknown's Avatar
nobodyunknown
Default Re: A/C PROBLEM (steve1ph)
That main wire runs close to A/C.wires did you perhapes burn more than 1 wire?Also you have a relay that you may check.
